Author Topic: Warning lights  (Read 3945 times)
Offline hastd2
  • Gti the Ultimate Hot Hatch...
Warning lights
« on: 26 December 2013, 15:01 »
Just not long washed my Gti, when finished I started it up and was going to reverse it out the drive then the hand brake wouldn't release automatically!!
So ended up doing it manually, which worked ok. I mind and seeing a thread about this issue so I left the car for 20mins and worked no bother :huh:
So about 30 mins later I had a trip to tesco and parked at the bottom end away from other cars,
So on my return I started up the car(keyless start) and 6 error messages appeared  :cry:
Auto hold error
ACC error
Tyre pressure error
And a couple of others which I don't know
So I pulled away from the car park up to the house and stopped the car, and switched it back on and the warning lights were gone!!!
Would this be something worth taking up with my dealer??
And what's the issue with the hand brake after you wash the car?
Will that be an ongoing issue??
Happy Boxing Day
Doug
Build Week 11.04.16 - 2016 Mk7 Golf R, Lapiz Blue 5 door manual, 12 months R/Tax, 2 yrs free service, full tank of fuel, sure guard, and private plate transfer
2015 Mk7 Gti 5 DR, Carbon Steel Grey, Performance Pack, Keyless Entry, Vienna Leather, and Sat Nav.
2013 Mk7 Gti 5 DR, Pure White, Performance Pack, Keyless Entry, Vienna Leather, and Sat Nav.
Offline dippy_x
Re: Warning lights
« Reply #1 on: 26 December 2013, 16:56 »
Hi Doug,
The breaks seems to be a bit sticky the first time after a wash - I have found it just needs a bit more oomph to get away that first time.
Re. The lights.  I would be inclined to wait and see if the error re-appears before taking into the dealers.
On Order: 02/05/13
GTD: Carbon Grey, Winter Pack, Keyless, High Beam Assist, Park Assist, Rear View Camera, Furry Dice
Collected: 06/11/13
Offline CraigW
Re: Warning lights
« Reply #2 on: 26 December 2013, 17:02 »
Did you put your seatbelt on when you reversed it out the drive? The brake won't release automatically if you don't have your seatbelt on
Offline C2K
  • Northern Monkey
Re: Warning lights
« Reply #3 on: 26 December 2013, 18:03 »
This is my thinking too.
5 Door Night Blue GTD
Dynaudio, 19" Santiago Alloys, Adaptive Chassis, Leather Pack, Winter Pack, Reverse Camera.
Bianca White 306 Rallye (Supercharged + Caged) : Melting Silver F54 Mini Clubman Cooper S
Offline hastd2
Re: Warning lights
« Reply #4 on: 26 December 2013, 18:55 »
Mmmmm......Seatbelt on!!!!....that might have been the problem  :laugh:
Never mind am sure it will fix its self out!!!
Will see if that lights come on again tho before I make the journey to the dealers
Offline monkeyhanger
Re: Warning lights
« Reply #5 on: 26 December 2013, 19:05 »
I've had the automatic brake failure/hill-hold failure warnings. Functionality was restored on next trip, had a few issues since that didn't trigger a warning in the MFD. First time the dealer just reset the error listings. When it happened again about a week later, a sensor and the switch were replaced.
Offline hastd2
Re: Warning lights
« Reply #6 on: 26 December 2013, 22:06 »
Might just pop along 2 Moro for a wee chat with the service manager and see what he has to say!!!
Offline simonpolly
Re: Warning lights
« Reply #7 on: 27 December 2013, 14:21 »
If they stick in the future just get the watering can and pour some water on the disc and pads you will find they then release easily
Golfgti build quality is average at best.
