Author Topic: Help with silicon hoses  (Read 5312 times)
Offline maxey
« on: 23 December 2013, 13:02 »
So iv had my golf Gti 1.8t for about 6 months and I have the fault code 17705 so iv found a split pipe but I have also found that the previous owner has bodged a copper pipe and t piece where the silicon hoses should go. I want to replace the hole lot with the proper hoses but not sure what they are called can anyone help?
Here is a picture
http://postimg.org/image/cku6uznc3/
Offline dom
  • Back in a Mk4
Re: Help with silicon hoses
« Reply #1 on: 23 December 2013, 13:10 »
All of that pipework looks to have been messed with, can you post a picture showing more of the engine bay? Also what is your engine code?
The hose coming off the rocker cover is just a breather pipe, silicone replacements can be had for about £30 off ebay but you need to make sure the rest of the pipework is ok before buying it.
« Last Edit: 23 December 2013, 13:12 by dom »
Offline maxey
« Reply #2 on: 23 December 2013, 13:59 »
Yh looks a mess doesn't it :( it's a AUM mate, il get a few pictures now mate thanks for the help btw I'm new to this car
Offline maxey
« Reply #3 on: 23 December 2013, 14:43 »
Here are some more pictures of my engine bay bud
http://postimg.org/gallery/szorw29a/a9bc9b92/
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 23 December 2013, 15:02 »
Has the SAI been plumbed into the breather system?!
Offline maxey
« Reply #5 on: 23 December 2013, 15:04 »
I'm not sure what SAI is bud
Offline dom
  • Back in a Mk4
« Reply #6 on: 23 December 2013, 15:08 »
Is there still the 'hockey puck' fitted? It's fitted behind the diverter valve and should look like this:
The breather hose with the red tape wrapped around it is common for splitting and should look like this:
Yours looks like it's been bodged instead of replaced, this is the hose that you need if you want to sort it:
http://www.ebay.co.uk/itm/Silicone-Crankcase-Breather-Hose-VW-Golf-1-8T-AUM-AUQ-/150993461267?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2327e96013
But it looks like the pipe it joins to has been changed as well. Can you take the lower engine cover off and get a picture of the corrugated pipe that goes underneath it?
Offline dom
  • Back in a Mk4
« Reply #7 on: 23 December 2013, 15:09 »
It's all a mess! I'm wondering if there is a catch can hidden away under the lower engine cover somewhere...
Offline maxey
« Reply #8 on: 23 December 2013, 15:22 »
I don't think there is a hockey puck I will go and check, il also get a picture with the lower engine case off, what's the pipe called under the one I need because I'm assuming I will need that one as well haha, just what I need on Christmas :(
Offline dom
  • Back in a Mk4
« Reply #9 on: 23 December 2013, 15:30 »
If it's missing it's just called a breather tube I think.
If it's the one highlighted in the picture above it's part number: 06A 103 213 BG
All the info above is from here:
http://uk-mkivs.net/topic/57294-breather-pipe-part-number-not-the-usual-2-from-awesome-gti/
