Author Topic: Magnetic Sump Plug  (Read 8893 times)
Offline Len
Magnetic Sump Plug
« on: 21 December 2013, 17:06 »
Where can I get one?
Ordered one and its too small. Ebay ones look the same
www.sas.org.uk
www.the-ace.org.uk
Offline Luke1981
Re: Magnetic Sump Plug
« Reply #1 on: 21 December 2013, 18:36 »
Awesome Gti stock them Len
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline Luke1981
« Reply #2 on: 21 December 2013, 18:45 »
Just checked their website and here is the link
http://www.awesomegti.com/ecs-magnetic-drain-plug-with-10-copper-washers
Is your engine an abf? If so, then the ones they stock won't fit.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #3 on: 21 December 2013, 19:05 »
I came across this issue when I ordered one from eBay a few years ago. My original ABF sump plug was f**ked anyway so drilled it and replaced with a large bolt which was tapped and bonded into the sump then the bolt was drilled and tapped to accept the new magnetic sump plug. Killed two birds with one stone.  :wink:
Offline boneybradley
  • Back in a Mk3...
« Reply #5 on: 21 December 2013, 23:04 »
Len
length: 23,8 mm
outside thread: M 14 x 1,5
A/F dimension: 19 mm
length under head: 16 mm
Offline Len
« Reply #6 on: 22 December 2013, 11:28 »
Thats the one I ordered on Awesomes say so and its wrong!
www.sas.org.uk
www.the-ace.org.uk
Offline Len
« Reply #7 on: 22 December 2013, 11:31 »
www.sas.org.uk
www.the-ace.org.uk
Offline mark-mk3gti
« Reply #8 on: 22 December 2013, 12:20 »
ive seen somewhere, possibly on "fast n loud" where when they bedded the engine in, they used a strong magnet and stuck it on the inside of the sump. it sticks it self to the sump and will collect the bedding in material, obviously you need to be careful where u stick it, so it doesnt get bashed and do damage, then run the engine in, drop the sump again and remove the magnet and all the running in material,
In my own head it seams a good idea to drop the sump after running in, to make sure there is as little as possible material left in the sump,
probably a rubbish idea, but thought id share it,, :)
VW BUSH
« Reply #9 on: 22 December 2013, 14:26 »
I'm tight so I magnetised the standard jobby on a mag chuck :grin:
