Author Topic: Gearbox oil seal leak help  (Read 5393 times)
Offline WeekendMechanic
  • Golf MK3 GTD
« on: 20 December 2013, 13:33 »
So my gearbox is leaking from the oil seal from right side, is it a just matter of taking out the drive shaft, unbolting the flanged shaft, tapping it out, and replacing the oil seal?
Offline boneybradley
  • Back in a Mk3...
Re: Gearbox oil seal leak help
« Reply #1 on: 20 December 2013, 16:11 »
drive shaft oil seal?
and yes that's the way to do them
  • Golf MK3 GTD
« Reply #2 on: 20 December 2013, 18:34 »
Yes drive shaft oil seal are you sure nothing is going to pop out on me when i remove the flange shaft?
  • Back in a Mk3...
« Reply #3 on: 20 December 2013, 19:35 »
my driveshafts have being on and off a few times and last time I did the seals (whilst the shafts were off), just ensure you use some nutlock on the bolts and it should be fine to reuse the old bolts (i put all new bolts on mine as it snapped a couple)
  • Golf MK3 GTD
« Reply #4 on: 21 December 2013, 05:29 »
Ok thanks for your help one last question do I need to drain the gearbox before I replace the oil seal?
  • Back in a Mk3...
« Reply #5 on: 21 December 2013, 12:08 »
I would drop the oil. Then again it's perfect time to do a change as mine was well past its best
Offline bigberty101
« Reply #6 on: 21 December 2013, 14:00 »
I personally thought the were bit of a pig to do with the gearbox in, I personally would remove the box and fit them that way
  • Golf MK3 GTD
« Reply #7 on: 21 December 2013, 15:21 »
Thanks for your concern but I will be working in a pit so it should not be too strain full,is there anything to watch out for or any tips to make the job easier?
  • Golf MK3 GTD
« Reply #8 on: 22 December 2013, 20:01 »
I managed to find this awesome http://www.brokevw.com/020flange.html
  • Golf MK3 GTD
« Reply #9 on: 30 December 2013, 16:35 »
One last question befor i order stuff from vw,my flange shaft green sleeve is kinked from previous owner,is this just a matter of taking the old sleeve out and replacing it with a new one or is it compressed inside,thanks in advance :)
