Author Topic: auq internals max power  (Read 6303 times)
Offline davidgtrr34
« on: 18 December 2013, 21:07 »
I was wondering what is the max power that auq internals can handle.
I have checked on google and I cant find a right answer.
I'm doing a big turbo upgrade and was thinking of mapping it to 330 bhp
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Offline dom
  • Back in a Mk4
Re: auq internals max power
« Reply #1 on: 18 December 2013, 21:17 »
It's torque that will bend things, not power :wink:
Offline davidgtrr34
« Reply #2 on: 18 December 2013, 21:20 »
I no but I don't no what torque I would get.
if I put a good oil cooler on to keep to con rods cooler would that help
Offline Scott D
« Reply #3 on: 18 December 2013, 21:35 »
300 ft-lb seems to be the magical figure atlhough known for standard unmapped torque to bend.
either change to forged or mapping done with rods in mind and drive sensibly - monitor oil temps and don't WOT low down in higher gears.
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline rockmonkey69
« Reply #4 on: 18 December 2013, 22:15 »
Cooler oil temp will not stop conrods bending, the problem with the standard conrods isn't just that they are the weakest part of the engine but also the most inconsistent owing to its manufacturing technique, so while one auq might run 350 ft-lb another might only hold 270 ft-lb, so there are two choices, you either run the engine and have a replacement at hand or you build it up before you for an uprated turbo.
Offline dom
  • Back in a Mk4
« Reply #5 on: 18 December 2013, 22:17 »
This ^^
I would personally prevent a problem rather than fix one
Offline davidgtrr34
« Reply #6 on: 18 December 2013, 22:20 »
what power would rods hold cause the turbo and injectors are good for round 380 bhp
« Reply #7 on: 18 December 2013, 22:59 »
The rods aren't just weak, they're inconsistent too. So it's not like one can say with absolute certainty where one person's rods will bend and where the next guy's bends. While one person might run 360 ft-lb for over a year, I've also seen cases where people have bent their rods at 270 ft-lb.
If you're asking what the lowest figure someone has bent their conrods, then from what I've seen I would say 270 ft-lb
Mates of mine have different approaches, as mentioned above they either build their engine from the start or has a spare engine ready. But not one believe the standard engine is reliable for 300 ft-lb or more.
Offline dom
  • Back in a Mk4
« Reply #8 on: 19 December 2013, 08:12 »
With that in mind, Toby's old MK4 made 304bhp and 286lb/ft with a KO4 - IMO that's about the safe limit for standard internals.
« Reply #9 on: 19 December 2013, 08:54 »
I built mine with forged rods and sleep sound, end of. Unless of course you get a steady and cheap supply of 1.8t engines, I've a few friends from Poland and according to them these 1.8t go for peanuts and unless your chasing 400+ bhp its more cost effective to replace the engine (assuming you're doing the work yourself)
