Author Topic: Golf Mk4 1.9 TDI turbo Whistling  (Read 1928 times)
Offline wegotitugetit
« on: 12 December 2013, 16:34 »
was told when i bought the car that this was done due to a upgraded turbo still need to check if that is correct or not
it does not whistle all the time if you put your foot down it will whistle not mega loud but i hate the sound of it
can any one confirm this can be sorted out is there something that needs to be adjusted
 i don't mind loosing a little HP if it stops
Offline jv
  • Administrator
Re: Golf Mk4 1.9 TDI turbo Whistling
« Reply #1 on: 12 December 2013, 17:29 »
You need access to the admin menu of the MFA. From there you can get to the turbo adjustment settings. Sounds like the turbo signal attenuator maybe quite high.
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline dom
  • Back in a Mk4
« Reply #2 on: 12 December 2013, 17:41 »
Just to add to what JV said, to access the admin menu of the MFA you need to do the following:
1. Ignition on.
2. Twist left knob (by the clock) anti-clockwise and the right knob (by the mileage) clockwise.
3. While holding both knobs turn the ignition off again.
4. Release both knobs.
5. Twist both knobs again and while holding them turn the ignition on.
6. The menu should now appear.
« Reply #3 on: 13 December 2013, 11:37 »
thanks guys daft question here
how do i know when I'm in where the settings are to adjust this and how do i know I'm adjusting it correctly
is it in the manual at all
can i make things worse if adjusted wrong  ????
Offline crazy golf
« Reply #4 on: 13 December 2013, 23:29 »
has the car got a induction kit or stock airbox?
Offline Rhyso
« Reply #5 on: 14 December 2013, 09:04 »
I suspect itd decatted hence the whistling
« Reply #6 on: 14 December 2013, 09:17 »
standard
« Reply #7 on: 14 December 2013, 09:17 »
will check that on my dinner
Offline Rhyso
« Reply #8 on: 14 December 2013, 11:10 »
Running a standard cat with upgraded turbo would be a total waste of time as the cat is so restrictive
Check your boost pipe connections for signs of oil. If there is oil residue them you got a boost leak
What BHP version is it?? Does it have a FMIC??
« Reply #9 on: 14 December 2013, 13:02 »
110 bhp
i presume by FMIC i can only guess front mount inter cooler ?? all I can say it looks standard but will check when i get home later on from work when i have more time to look at the car
