Author Topic: Bit of a problem, help needed please.  (Read 881 times)
Offline JWebb
« on: 11 December 2013, 22:28 »
Hi all,
I've had a few problems in the last week or two
namely being when I first turn the car on it automatically revs itself to about 3000 revs then drops back down to idle, I've had two fault codes, the lambda sensor needs changing again and engine temp sensor is faulty as well would this cause it to rev?
Thanks,
Jack
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Bit of a problem, help needed please.
« Reply #1 on: 11 December 2013, 22:30 »
Maybe, but get those faults fixed first as they'll be costing you a lot of fuel
Offline JWebb
« Reply #2 on: 11 December 2013, 22:37 »
I'm starting to wonder whether the lambda sensor is the actual fault as I only changed that two months ago, there is a strong smell of petrol at times so I guess this is consistent with that not working though?
I'm averaging 30.8MPG at the moment which with the miles I do is costing far too much!
Jack.
Offline mcgee9t2
« Reply #3 on: 11 December 2013, 23:14 »
id guess that the engine temp sensor is making the engine over fuel....
could have a broken lambda too, not sure...
however, im sure ages ago someone said about temp senders being the cause of high idle on start up, but that was more like 1200 ish not 3k
