Author Topic: Timing belt / Chain Help  (Read 1879 times)
Offline wegotitugetit
« on: 10 December 2013, 11:07 »
Hello guys and girls 1st post here
well bought myself a Vw Golf Mk4 Gt Tdi Last Night 2000 plate
any idea if this is belt or chain and what is the recommended intervals
how do i check which engine i have ????
don't know enough about these have basic knowledge my 1st ever vw always been a vauxhall person
« Last Edit: 10 December 2013, 11:10 by wegotitugetit »
Offline mcgee9t2
tRe: Timing belt / Chain Help
« Reply #1 on: 10 December 2013, 11:17 »
belt iirc. only a chain on the r32.
believe the intervals are around 60k
have a look in the service book, should say.
Re: tRe: Timing belt / Chain Help
« Reply #2 on: 10 December 2013, 11:18 »
didn't come with one and no history with it either , its in a garage now but there autodata couldn't tell them must be too old
anyway order one now there going to fit it at same time there doing a few small jobs on the car
« Last Edit: 10 December 2013, 14:32 by wegotitugetit »
Offline navmk4gti
« Reply #3 on: 10 December 2013, 12:09 »
Aint just r32. The 2.8 V6 4mo has chain too :wink:
Offline matt@onlychargeddubs
« Reply #4 on: 10 December 2013, 15:44 »
I'd be a bit worried about the garage if they had to look on Autodata to find out if it was belt or chain!
« Reply #5 on: 10 December 2013, 15:59 »
it was before they looked under the hood
the main thing is vauxhall's lol , i always took my cars there spot on guys
i wanted to know oil specs etc so they just looked straight on to the auto data
Offline mike1990
« Reply #6 on: 10 December 2013, 16:37 »
My autodata is just coming up with timing belts, although I can't be too sure without knowing the engine code
Offline MoshiMoshi
  • Scorpion Exhausts are delightful.
« Reply #7 on: 10 December 2013, 19:09 »
It's a timing belt from the crank to the exhaust camshaft. From the exhaust camshaft to the intake cam is a chain mounted on the other side of the cylinder head. I think it's that way round.
I thought Volkswagens were supposed to be reliable?
Offline mcgee9t2
« Reply #8 on: 10 December 2013, 22:45 »
wasn't sure on the 4mo or whether it was just the r that had it :D
« Reply #9 on: 11 December 2013, 09:45 »
No it's just a cambelt, 1.8T's have chain on the cams.
Easy belt to swap but they need timing pins as the cam pulley is variable, both cam and crank HAVE to be locked off, you can physically do it without locking them off and it'll run but it messes with injector timing and it can run rough or just very down on power :wink:
