Author Topic: no boost  (Read 4177 times)
Offline davidgtrr34
no boost
« on: 09 December 2013, 21:00 »
I have a 2004 gti, auq engine code. my turbo wont boost, car is running sound, no noises, not using oil, no smoke or anything.
When stopped if I rev it I can hear the turbo spool but it wont spool under load.
Has anyone ever seen this before
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Offline james2
  • No scammers please.
Re: no boost
« Reply #1 on: 09 December 2013, 21:12 »
is it mapped if not, mine was lame before it was mapped  :evil:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline james2
Re: no boost
« Reply #2 on: 09 December 2013, 21:13 »
Also scan it for any faults.  :smug:
Offline davidgtrr34
Re: no boost
« Reply #3 on: 09 December 2013, 21:30 »
Its not mapped but it is running around 210bhp.
ive scanned it and no fault codes
Offline barrym381
Re: no boost
« Reply #4 on: 09 December 2013, 21:32 »
210bhp from a non mapped auq  :shocked:
Offline davidgtrr34
Re: no boost
« Reply #5 on: 09 December 2013, 21:33 »
6 bar fuel pressure and 1.2 bar boost
Offline Nino
Re: no boost
« Reply #6 on: 09 December 2013, 21:53 »
It must be mapped. The auq was 180 standard anything higher I'. Sorry it's mapped.
To answer your question I'd take a guess that you have a boost leak.
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline davidgtrr34
Re: no boost
« Reply #7 on: 09 December 2013, 21:58 »
its not mapped. Ive done all the work myself
mods are fmic, ebc, adjustable fuel pressure regulator, walbro 255 fuel pump and diode mod
Offline Nino
Re: no boost
« Reply #8 on: 09 December 2013, 22:11 »
Then you have made adjustments and your car would naturally need a map now that's your issue.
Offline EsSeX dAn
Re: no boost
« Reply #9 on: 09 December 2013, 22:14 »
take the diode mod off, it might have chucked the car into limp mode. euther that or the actuator has gone soft
i think i love you.....
