Author Topic: no boost  (Read 4175 times)
Offline davidgtrr34
Re: no boost
« Reply #10 on: 09 December 2013, 22:15 »
Then you have made adjustments and your car would naturally need a map now that's your issue.
I don't want to map it yet cause im currently doing a big turbo upgrade.
Did you ever hear of a wastegate flapper breaking.
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Offline davidgtrr34
Re: no boost
« Reply #11 on: 09 December 2013, 22:18 »
take the diode mod off, it might have chucked the car into limp mode. euther that or the actuator has gone soft
I don't think its the diode because I had limp mode before and it was running 3psi but now it only stays in vacuum it wont even hit 0 psi
but ill try removing it anyway and see what happens
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: no boost
« Reply #12 on: 09 December 2013, 23:18 »
actuator still connected?
Offline davidgtrr34
Re: no boost
« Reply #13 on: 10 December 2013, 06:43 »
ya its connected. should it be easy to move it by hand
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: no boost
« Reply #14 on: 10 December 2013, 12:40 »
Not really...
Offline davidgtrr34
Re: no boost
« Reply #15 on: 10 December 2013, 18:12 »
Not really...
It moves very easy and it springs back when I let go.
Is there any way to test it without removing the turbo
Offline davidgtrr34
Re: no boost
« Reply #16 on: 10 December 2013, 21:15 »
I scanned the car again and I got 6 fault code and have no idea how to fix
p0102  maf sensor
p0507 idle control system rpm
p1355 cylinder 1 ignition circuit
p1358 cylinder 2 ignition circuit
p1361 cylinder 3 ignition circuit
p1364 cylinder 4 ignition circuit
Offline barrym381
Re: no boost
« Reply #17 on: 10 December 2013, 23:08 »
p0102  maf sensor
have you checked with vw to see if your car is due coil packs under the recall they had  :smiley:
Offline davidgtrr34
Re: no boost
« Reply #18 on: 11 December 2013, 18:19 »
p0102  maf sensor
cheers man I rang vw and im getting some free coils
Offline barrym381
Re: no boost
« Reply #19 on: 11 December 2013, 18:25 »
p0102  maf sensor
free stuff is great  :grin:
