Author Topic: Rough idle when warm?  (Read 13380 times)
Offline Gambit
Re: Rough idle when warm?
« Reply #40 on: 14 December 2013, 19:23 »
Does your mfa work correctly? Do you get an mpg. If not then as prev mentioned itll be that.
Also check if the ecu has its vacuum line fitted. Ecu is under scuttle at driverside
there is also a vacuum line that goes to side of airbox to control the air direction flap, so that it sucks warm air off manifold on cold starts
Offline pullafacial
« Reply #41 on: 14 December 2013, 20:18 »
Mfa works (apart from cracked screen!)
Shows around 35mpg but only achieving about 24 atm.
Vacuum pipe is connected to the airbox flap. Checked the vacuum which works ok but flap is a bit temperamental.
I'll check the vacuum pipe on ecu, is it in passenger footwell bit?
Offline Gambit
« Reply #42 on: 14 December 2013, 20:55 »
Ecu is under scuttle under the bonnet  on driverside
There is a big metal bracket tci mounted to top and ecu on the underside
Offline Gambit
« Reply #43 on: 14 December 2013, 21:05 »
Very top left hand corner of this pic behind the suspension turret you can see the plastic cover for the ecu
