Author Topic: Engine removal  (Read 6500 times)
Offline Len
Engine removal
« on: 03 December 2013, 11:51 »
So how do I do it?
prefer to leave rads and aircon stuff insitu. Will be taking bonnet off completely.
Will I be able to leave the gearbox in the car?
Do driveshafts have to be removed?
Thought I would ask here before I consult Haynes!  :grin:
www.sas.org.uk
www.the-ace.org.uk
Offline DCmk3
Re: Engine removal
« Reply #1 on: 03 December 2013, 12:23 »
I assume you don't want to follow this method?  :whistle:
http://www.youtube.com/watch?v=S8j-Hjb-WrY
However the last time I pulled an engine it turned out to be easier to remove the gearbox from the car separately from the engine before trying to remove the engine to give you more room to work with.
We left the driveshafts connected to the hubs when removing the engine, but it might be safer to just remove them all together then having them hang around in the bay if you pull the gearbox too.
2014 Mk7 GTI - Littco L500
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
Re: Engine removal
« Reply #2 on: 03 December 2013, 14:09 »
 :laugh: :laugh: :laugh:
Offline Len
Re: Engine removal
« Reply #3 on: 03 December 2013, 14:43 »
No not that method !!!  :laugh:  :laugh:
By the sound of it I might as well take everything out then!
www.sas.org.uk
www.the-ace.org.uk
Offline murraymint
Re: Engine removal
« Reply #4 on: 04 December 2013, 19:59 »
I know it's a pain because of discharging the air on, but the easiest way by far is taking the front end off then you can pull everything out of the car from the front in one lump.
josh
Offline Len
Re: Engine removal
« Reply #5 on: 04 December 2013, 20:10 »
No way am I disconnecting the aircon!
Sure I can do it without, will just have to hang the pump off something.
Was more interested in if I can leave the gearbox in
www.sas.org.uk
www.the-ace.org.uk
Offline DCmk3
Re: Engine removal
« Reply #6 on: 05 December 2013, 04:18 »
The biggest problem is the gearbox has one mount on the end of it, the whole other side of the box is supported by the engine.
I don't think you would have enough room to manoeuvre the engine out of the bay with the box still in the car.
Offline spikenipple
Re: Engine removal
« Reply #7 on: 05 December 2013, 07:52 »
There will be enough room to get the engine and box assembly out together. When I broke a 16v for spares a couple of years ago the chap that had the engine got the lot out together without any drama.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Engine removal
« Reply #8 on: 05 December 2013, 07:54 »
As far im aware they can both be taken out in one piece with the front of the car removed.
Offline Len
Re: Engine removal
« Reply #9 on: 06 December 2013, 13:18 »
So how would you do a clutch replacement then?
www.sas.org.uk
www.the-ace.org.uk
