Author Topic: Rim sizes - will they fit?  (Read 5071 times)
Offline BoSelecta
« on: 02 December 2013, 21:53 »
Hi Guys - sorry if I've missed a thread somewhere but just wondering if these lads will fit my 1991 mk2 Ryder 1.6:
Rim Width: 7J
Rim Diameter: 15
Offset: et26
4x100 pcd
Center Bore: 57mm
Tyres on 'em: 195/55/15
Pretty sure they will fit based on my Internet research but hoping for clarification from someone who knows what they're on about!
Offline Waspy
Re: Rim sizes - will they fit?
« Reply #1 on: 02 December 2013, 21:59 »
I had some 7j et20 or 25, don't remember, and they didn't really fit, although there was a fair drop on the car at the time. There is a tool somewhere that let's you compare clearance between wheels. I'll see if I can find it.
Edit: http://www.1010tires.com/Tools/Wheel-Offset-Calculator#Results  - brilliant tool.
« Last Edit: 02 December 2013, 22:01 by Waspy »
Offline JC
  • Back in the North.
« Reply #2 on: 02 December 2013, 22:09 »
just a few threads missed, narrow ya search down to the mk2 section only  :wink:
Quote
Rim Width: 7J             yep - fine
Rim Diameter: 15          yep - fine
Offset: et26                yep - fine
4x100 pcd                   yep - fine
Center Bore: 57mm        yep - i presume you mean 57.1mm ?
Tyres on 'em: 195/55/15     standard are 195/50 15s, so they will be a tad balloon like in the sidewall department and dependant on how low you are might give you some scrubbage -
they will also throw your speedo out.
 :smiley:
Offline BoSelecta
« Reply #3 on: 03 December 2013, 11:24 »
Brilliant cheers guys - picking 'em up later this week. Will throw a pic up when i get them on...
Offline BoSelecta
« Reply #4 on: 03 December 2013, 14:29 »
A quick one, just seen on this website:
http://www.wheelfitment.net/vw
It's saying a Golf mk2 4 stud should have an offset of between 35 and 40. With these being a 26 offset is this going to pose me any problems?
Offline e30adz
« Reply #5 on: 03 December 2013, 15:51 »
Hi, i had some 7j et24 15's with 195/50/15 tyres on my gti which is lowered roughly 30mm and with my 2 kids (both 8yrs) in the back it would scrub, on my own it was ok most of the time. If your cars standard ride height or you have no family or friends you should be ok. But if its lowered and with 55 profile i think you'll get lots of scrubbing.
Offline BoSelecta
« Reply #6 on: 03 December 2013, 16:22 »
Thanks for the input - I may need to look into changing the tyres to a 45 profile quicker than i had thought. Luckily I haven't yet lowered so i'll have to coincide buying coilovers with buying new tyres!
Offline Mcwill
« Reply #7 on: 08 December 2013, 01:35 »
Hi guys I have been looking at some rims for a while now but they are 7" et42 15"? So would they not fit? My car sits very low as well. :huh:
Any help would be great.
Offline BoSelecta
« Reply #8 on: 08 December 2013, 20:23 »
You should be fine with those McWill (from what I've been reading). The mk2 recommended offset is 35-40 so you're gonna be well within the wheel arch. Only thing thing to make sure is will the disc etc all fit inside which should be fine on a 15"
Offline JC
« Reply #9 on: 08 December 2013, 20:26 »
problem is they could be TOO FAR inside the arch  :lipsrsealed:
and rubb against the struts, and even the inner arch.  :lipsrsealed:
only one real way to find out.  :smiley:
