Author Topic: Rim sizes - will they fit?  (Read 5074 times)
Offline BoSelecta
Re: Rim sizes - will they fit?
« Reply #10 on: 08 December 2013, 20:31 »
Can always use spacers if needed, as chuff says; one way to find out
Offline Gambit
« Reply #11 on: 08 December 2013, 20:48 »
Stick a spacer on it if need be
Offline Mcwill
« Reply #12 on: 09 December 2013, 23:30 »
Thanks for the replys, also seen another set of rims with et25, so am I rite in thinking that the et42s would catch on the inner arches and the et25s would catch the outer arches? So witch would be the better of the two? If I had to use wheel spacers on the et42s then would they aso not catch the out arches? Sorry all the questions  :tongue:
Offline BoSelecta
« Reply #13 on: 10 December 2013, 09:09 »
I've just fitted et26s and they fit perfectly... With no drop. I think when I come to lower I will struggle to go further than -40mm so it all depends what u want. You would space the 42s so they sit just where u want them so, everything else being equal, they are your best bet I'd imagine
Offline Sgt_Lemon
  • 8v owners club
« Reply #14 on: 10 December 2013, 20:14 »
One way to look at it is if you need to add spacers you can. If it's scraping badly on the outer arch then it's a much bigger job or impossible to get them to fit.
Offline Mcwill
« Reply #15 on: 10 December 2013, 21:46 »
The car is lowered 60mm on the back and 50mm on the front so not sure the et25's would be a good call. Although I am getting the arches rolled.
