Author Topic: Stuck rocker cover!!!!!!!!!!  (Read 1040 times)
Offline Vag for life
« on: 02 December 2013, 19:40 »
Hey guys iv got a mk4 1.8t aum golf gti and have a leaking Rocker cover gasket, iv had att the bolts out and coil packs ect and tryed to pull it off but it wont budge no matter how hard i pulled it wont move an inch has anyone got any ideas how i can get it off with out breaking it?? any help would be greatfull
Offline barrym381
Re: Stuck rocker cover!!!!!!!!!!
« Reply #1 on: 02 December 2013, 19:42 »
try mans best friend a big hammer and a block of wood but double check you have all the bolts  :smiley:
« Reply #2 on: 02 December 2013, 19:51 »
thanks dude will give it a try was abit worried about breaking the cover but worth a shot, iv done afew but never had this problem before like
Offline sharki786
  • GOT BOOST??
« Reply #3 on: 02 December 2013, 20:31 »
Dont need to use the hammer. I know you said you removed the coilpacks but have hou removed the sparkies?? Not sure if they stop the rocker from comming off but worth a try. Double check all around the rocker you might have missed a bolt
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline harkerg
« Reply #4 on: 02 December 2013, 20:39 »
Plugs dont stop the rocker its prob been diyd with silicone instead of a propper gasket try a small flat ended pry bar try tapping it in and lever it gently
« Reply #5 on: 02 December 2013, 23:00 »
Hit with mallet softly :grin:
Offline Nino
« Reply #6 on: 02 December 2013, 23:16 »
There will be 3 bolts at the back and there will be a bracket in the way. Get a flat head and pry it from each corner it will come but it also on threads. You need to pull it straight up or it won't come off
Current - MK6 GTi Edition 35 - Candy White - 3 door
