Author Topic: 1.8t misfire  (Read 2624 times)
Offline ginga
1.8t misfire
« on: 02 December 2013, 13:21 »
this months episode of car problems is misfire. Im thinking coil packs maybe as the plugs were only just changed couple months ago... so any ideas on how a non mechanic minded gimp like me would be able to check
Offline barrym381
Re: 1.8t misfire
« Reply #1 on: 02 December 2013, 13:22 »
what year is the car  :wink:
Offline mar_k
Re: 1.8t misfire
« Reply #2 on: 02 December 2013, 13:41 »
Is it misfiring under load or all the time, even when idling?
What engine code is it? AUM's can some times bring up a code showing which cyclinder has the misfire.
If its missing on idle you could try unplugging the coils 1 at a time and listen for a change.
If you have a dead coil when its unplugged the engine idle wont change at all.
Offline ginga
Re: 1.8t misfire
« Reply #3 on: 02 December 2013, 13:47 »
sorry yeah its an ARZ and it sounds bad idle. but under acceleration its awfull and makes the car shake until 3000rpm
Offline mar_k
Re: 1.8t misfire
« Reply #4 on: 02 December 2013, 13:54 »
Try unplugging one coil at a time, When you unplug a good coil the car will run really bad or die.
when you find a bad one there will be now change. You may have more than one dead coil.
Offline ginga
Re: 1.8t misfire
« Reply #5 on: 02 December 2013, 14:18 »
cool I shall nip out and check now
Offline ginga
Re: 1.8t misfire
« Reply #6 on: 02 December 2013, 14:58 »
number 3 seems to be knackered.
Offline barrym381
Re: 1.8t misfire
« Reply #7 on: 02 December 2013, 15:01 »
does your car have an ignition amp  :undecided:
Offline ginga
Re: 1.8t misfire
« Reply #8 on: 02 December 2013, 16:06 »
Yeah i believe it does. Just ordered another coilpack £47 from vw
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: 1.8t misfire
« Reply #9 on: 02 December 2013, 17:16 »
No the ARZ doesn't have one. You should check if your car is part of the recall with VW
