Author Topic: Fitting Porsche wheels/ What suspension set up needed?  (Read 1754 times)
Offline 16valve
Hi all,
Need a little help on whats needed to keep the standard arches on a 1990 16v from eating my tyres on Design 90's, was thinking of buying all four at 6" as opposed the 6" fronts and 7/8" rears and using 195/45/16's and a make with hardly any sidewall? Would they look like bicycle wheels viewed at the rear?
Will be getting it lowered in the near future, but again which set up do I get to help prevent rubbing,not after to low just a touch -30? .. .My friend had Spax shocks and springs in he's Rs turbo and it gave about the worst ride EVER(like a skateboard) so not getting Spax, any info would be appreciated
Thanks Guys and Gals   Dave
Offline Organisys
  • Old and Slow...
Re: Fitting Porsche wheels/ What suspension set up needed?
« Reply #1 on: 23 August 2005, 18:31 »
hmm, this is going to be close me thinks. 6" with the adapter will be close one it's lowered. You can go -20mm on a valver with the longer length Eibach springs. They come in two drops.. Look at the www.awesomegti.com
Judderi
« Reply #2 on: 24 August 2005, 10:23 »
If you can get a full set of 6" wheels then i dont think you will have any problems. My fronts are 6" with standard arches running very low on coilovers and 30mm adaptors ET25. The rears however are 8" ET25 and 30mm adaptors and my arches are cut and rolled.
Offline Dizzie
  • Make friends with your fast
« Reply #3 on: 24 August 2005, 12:48 »
if you buy 2 sets I'll buy teh 4x7" off you :D
Judderi
« Reply #4 on: 24 August 2005, 12:53 »
Or if you get a mixed set like mine i will do you a swap so we both have a full set of the same sizes. Swap 6 or 8's i dont mind.
Offline 16valve
« Reply #5 on: 25 August 2005, 16:11 »
Thankfully havn't got to buy 2 sets,as i've found a set of 6's ..
Not sure of the going rate but will probably end up parting with £200  :cry: plus adaptors ohh plus those shiny metal centres  -  err and tyres!! Feck was going to get BBs Rm's but thought there a few quid at this rate I could get either   :undecided:
Thanks for offers to buy other set or even swop a set - glad im on this site seems friendly..
Hopefully may see some of your cars at No Rice meet on sunday as I live in Brighton so will be coming even if my Bloody cars not fixed ( fuel pump now!!)
Thanks Dave
Judderi
« Reply #6 on: 26 August 2005, 10:34 »
That seems quite cheap. Are they standard or polished?
Offline 16valve
« Reply #7 on: 26 August 2005, 18:53 »
Not sure if thats cheap or not (standard for now) as need to put tyres on as well, but didnt really think about all that when i was armed with telephone and the plastic   :grin:  its just those little metal shiny centres that do it for me, really wanted coloured centres but they'll have to wait ....
