Author Topic: key problems  (Read 956 times)
Offline poolhump
key problems
« on: 27 November 2013, 16:03 »
hi everyone, i have recently bought a mk 4 2002 golf 1.8t gti and im having a lot of problems with it. a problem that occured today was that i started the car and the key can be removed from the ignition with the engine still on, i had a mk 4 gt tdi and im sure you couldnt do that on that car. does anyone have idea how to fix it ? the key looks shabby and a bit bent. im looking in to getting a new one cut. do you think that will solve the problem
Offline Nino
Re: key problems
« Reply #1 on: 27 November 2013, 16:37 »
It should not do this....
Sounds to me like someone has had a go at the barrel  :undecided:
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline Tezmax
Re: key problems
« Reply #2 on: 27 November 2013, 16:52 »
Cant see a new cut key would make any difference either.
Best get a new ignition barrel made up from VW dealers, won't be cheap :sad:
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
