Author Topic: Front strut movement  (Read 2308 times)
Offline Carl!
« on: 25 November 2013, 22:15 »
After fitting my Joms I had to re-higher one of the struts and re tighten a month or so later. Anyway I've done this and it has happened again, even though I was mindful and tightened the sh!t out of it, or so I thought! Any tips on sorting this out? I proper tightened it so i'm presuming it must have got some lubricant or something on the strut?! Anyone had similar and sorted it?!
Offline dom
  • Back in a Mk4
Re: Front strut movement
« Reply #1 on: 25 November 2013, 22:53 »
Do you mean the adjusters are working their way down the threads?
Offline Carl!
« Reply #2 on: 26 November 2013, 18:39 »
No the actual strut has dropped further through the holder. Im going to qdjust it again and tighten it but wondered if it was maybe a common occurance and a way of stopping it.
« Reply #3 on: 26 November 2013, 20:21 »
Replace the pinch bolts with new, then torque to spec.
Offline Carl!
« Reply #4 on: 26 November 2013, 22:20 »
Will give it a go. Thanks. Edit@ any ideas on size of the bolt? Had a search but as you can tell with my attempt at explaining i'm not massively up on this sort of thing!
« Last Edit: 26 November 2013, 22:27 by Carl! »
