Author Topic: Engine Number  (Read 2534 times)
Offline grobinson
Engine Number
« on: 25 November 2013, 21:27 »
Evening
I bought a Mk3 GTi 16V anniversary a couple of months back, I love it.
Put it into a local specialist for a timing belt change and it seems that the engine has an aircon pump on it but no aircon.
Therefore I have to assume the engine has changed?
Where can I find the engine number so I can cross reference it with the V5 for starters, then is it possible to trace the engine history if it has been changed?
Thanks
Graeme
Offline spikenipple
Re: Engine Number
« Reply #1 on: 25 November 2013, 22:20 »
You'll find the engine number on the sticker on the cam pulley cover, or if that's missing then on the block somewhere...
Offline grobinson
Re: Engine Number
« Reply #2 on: 05 January 2014, 11:04 »
Hi
thanks...yeah the sticker isnt there now, its on the block i am looking
Re: Engine Number
« Reply #3 on: 05 January 2014, 16:31 »
Hi
Should be on the front of the block just underneath the head gasket joint.
Offline grobinson
Re: Engine Number
« Reply #4 on: 05 January 2014, 20:59 »
Right my bad.... Sticker is on the cover and that matches with the v5
still cant find the engine number in the dark with a torch...im hoping daylight will help!!
can you get the engine number from the vin?
cheers
