Author Topic: Ecu chipped now car won't start  (Read 5428 times)
Offline spudboy6
  • Just like a golf ......
Re: Ecu chipped now car won't start
« Reply #10 on: 24 November 2013, 21:17 »
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #11 on: 24 November 2013, 22:09 »
That looks really shoddy mate, it's no surprise it won't work.
VW BUSH
« Reply #12 on: 24 November 2013, 23:09 »
one of the pins is missing solder
Offline spudboy6
« Reply #13 on: 24 November 2013, 23:39 »
Yea I'm glad I never paid them for it !
I'm going to solder the pins again my self in the morning and hope or else I'm changing the ecu
Offline chris_d66
  • Golf GTI 16v,A3 1.8t,Rocco, Range rover V8
« Reply #14 on: 24 November 2013, 23:52 »
Also check under the socket as it may have tracks on both sides of the PCB. hopefully the chip will be ok but it is possible to damage both chip and ECU if the tacks are not soldered correctly or they have dry joints.
New toy1990 Scirocco I feel a 16v conversion coming on.
Offline spudboy6
« Reply #15 on: 25 November 2013, 23:50 »
Right I checked all pins on the chip against the motherboard with a bolt metre and every pin is making contact from the pin to where the other end if the board goes as such
So my ecu is pronounced dead , even caf come won't read it anymore !
New ecu going in tomorrow and its going to a proper mapping company down the road I didn't even know about for a custom map
« Reply #16 on: 25 November 2013, 23:56 »
I would save your money, on a 1.8 any gain will be tiny.
Offline spudboy6
« Reply #17 on: 26 November 2013, 00:04 »
I completely agree with you , BUT I'm attached to the car and dont want to change it so even for a small gain I'm willing to give it ago
Offline spudboy6
« Reply #18 on: 26 November 2013, 21:18 »
Ecu swapped over this evening but seem to have a problem with my timing now
Sure its timed up right but will check in the morning
Revs up fine from standstill but takes a while to start and pops and bang lots and is very very slow
« Reply #19 on: 26 November 2013, 21:37 »
Seems strange, is it the correct ecu for the year/model
