Author Topic: It's been a while....  (Read 3937 times)
Offline MontanaGTD
« on: 20 November 2013, 20:48 »
But back in a mk2! Sold my GTD 5 years ago!!
Now is a white E plate GTi 8v (Pb engine / Wolfsburg shell / CE1 electrics)
It misfires like hell!!
So far this is list of replaced items
Plugs
Leads
Coil
Dizzy (twice as first had a faulty hall sender and made it worse!)
Fuel filter
In tank pump
Tci-m ignition booster.
Still missing badly!! Any ideas??
Offline MontanaGTD
Re: It's been a while....
« Reply #1 on: 20 November 2013, 20:51 »
Replaced fusebox and fuel pump relay too as windscreen leaks and rust was an issue inside the fusebox
Offline Mart8V
  • I really should know better by now.....
« Reply #2 on: 20 November 2013, 21:27 »
Being an E reg PB you will have the screw in temp sensor on the coolant housing.  Have you replaced that?
Offline MontanaGTD
« Reply #3 on: 20 November 2013, 22:01 »
I've got one here to do, along with the small temp sensor for the clocks as it's temperamental!!
Think that's causing it??
Offline MontanaGTD
« Reply #4 on: 20 November 2013, 22:56 »
Forgot to say the rev counter twitches just before it misfires
Offline gazareth
« Reply #5 on: 20 November 2013, 23:03 »
is it a constant misfire or intermittent? is it worse when engine hot or cold? when accelerating hard or cruising?
Offline MontanaGTD
« Reply #6 on: 21 November 2013, 07:43 »
It's intermittent - no pattern. Does it when hot, when cold, cruising accelerating, even when decelerating, on good fuel on supermarket fuel.
Offline clipperjay
« Reply #7 on: 21 November 2013, 09:51 »
Was 2nd one brand new?
Was the king lead changed aswell?
Possible injector down or the wire harness is old and melted causing intermittent firing of fuel
Offline Mart8V
« Reply #8 on: 21 November 2013, 13:58 »
Not a miracle cure but always worth changing if you do not know how long the old one has been in.
Offline stugtd
« Reply #9 on: 29 November 2013, 20:15 »
I might look at the coil if I was you as the rev counter works of a pulse from the coil.
as you said it happens just after it starts jumping hope this helps
