Author Topic: Mk6 electric steering issue  (Read 1505 times)
Offline bornlivelife
« on: 20 November 2013, 16:41 »
Hello
My 2009 Mk6 1.6 Diesel has got a steering issue
sometimes it is fine for days, then the yellow light or sometimes red light with steering wheel logo can come on, the wheel jerk, then it will drive fine
sometimes the light goes on, then goes off again, with no change in the steering
sometimes the light will be on when I start the engine, then go off after 10 seconds and be fine
do you think it is a loose connection or how do I fix this?
thank you
Re: Mk6 electric steering issue
« Reply #1 on: 21 November 2013, 15:47 »
Also:
sometimes the light will come on if I go over a speed hump, or if I make a left turn when it is cold
and then it will go off again
Offline dubber36
« Reply #2 on: 21 November 2013, 16:29 »
Your first job to do is to get it scanned for fault codes. If the light has come on, there will more than likely be a code stored.
Offline Rhyso
« Reply #3 on: 22 November 2013, 11:57 »
Have you checked the fluid level??
