Author Topic: Could forge007p damage turbo because car is down on power?  (Read 1305 times)
Offline D1andonlyantman
Hi. I'm 95% sure my car is down on power because of a dodgy exhaust. It can't even redline in 4th. I'll be getting a new exhaust system very soon so that's not an issue. What's concerning me a bit is I read online that a forge007p can damage a turbo if the spring is too stuff because the turbo isn't creating enough power to open the valve once you let off the throttle. Because my car is down on power is that something I should be concerned about or am I worrying about nothing? It's only got the green spring in it so I guess I've got nothing to worry about considering this is the same setup that goes in the less powerful 150bhp models??
Thanks
MKIV AUQ - RamAir Induction Kit, Forge007p, (Custom Exhaust, Decent TIP, N249 Bypass and remap coming soon)
TRASHED BY SOME BELLEND WHO CANT DRIVE
Replaced with Leon Cupra 225, RamAir CAI, Forge 007p, Badger5 TIP, N249 bypass, Scorpion Decat and Catback, R-tech remap pushing approx 275bhp :-)
Re: Could forge007p damage turbo because car is down on power?
« Reply #1 on: 19 November 2013, 18:20 »
Well I figure I might as well update my own thread and say I put the 007p on and it seems to work fine although I haven't taken it for a proper spin yet... Looks like I was just being paranoid. I suppose my dodgy exhaust wouldn't stop the turbo producing power anyway but this is all new to me and I like to be sure.
Offline Nino
« Reply #2 on: 19 November 2013, 20:14 »
A DV wont damage a turbo unless it has a bugged piston
Current - MK6 GTi Edition 35 - Candy White - 3 door
« Reply #3 on: 19 November 2013, 20:19 »
The thing I read that made me paranoid was someone saying they were losing boost on a yellow spring but forge had said that was the correct spring for his hp and if he went higher it could cause turbo damage, I presume from the piston not moving because there wasn't enough pressure. Just got me thinking (and worrying)
Offline Nino
« Reply #4 on: 20 November 2013, 08:07 »
Well my car is not yet mapped and I'm using a yellow spring
