Author Topic: cut out whilst driving  (Read 3601 times)
Offline vwwvgolf
« on: 14 November 2013, 19:22 »
theres a road that i drive along regularly with what i can only describe as a trench going from one side to the other. it looks like where they have dug it the road up at some point and refilled it but its sunk.
when ever i go over this my engine cuts out and all the dials drop.
 it dont normally drive down there when its dark but tonight i had to and so all my lights went out part from my side lights and could hardly see anything.
its not to bad, as it only seems this particular bit of road but scared it will happen when the girlfriend is driving and it all goes wrong!
this ever happened to anyone else before? any one got a guess as to waht it is?
« Last Edit: 15 November 2013, 17:39 by vwwvgolf »
Offline vwwvgolf
Re: cut out whilst driving
« Reply #1 on: 16 November 2013, 10:27 »
no one??
Offline Shizzle
« Reply #2 on: 16 November 2013, 10:55 »
sounds like you have a bad connection somewhere and it it causing problems on a bumpy road.
Not a common problem from what i have experienced sounds like you need to go through the wiring on your light as they are injunction with dials as i have a problem when i turn my lights on my dial spaz out and reset so somewhere in the wiring the use same earth/live and one can cause problems with the other.
MK3 Golf GTI 2.0 16v 3Door Storm Grey
Offline vwwvgolf
« Reply #3 on: 16 November 2013, 16:38 »
so you think it has something to do with the headlight wiring?
 im just worried this will be untraceable!
Offline itavaltalainen
« Reply #4 on: 16 November 2013, 16:40 »
got many keys on your keychain?
sounds like the ignition switch is a goner
Offline hobbiniho
« Reply #5 on: 16 November 2013, 19:32 »
yeh the ignition switches are a common fault i had a problem that my car wouldnt turn off :laugh: it was like having a turbo timer as it still ran when the key was turned off and taken out  :grin: the switch is cheap enough but a complete ball ache to replace
Offline vwwvgolf
« Reply #6 on: 16 November 2013, 20:45 »
i dont have that many but i have recently added another key lol
thanks guys i will have a look into this!
Offline mark-mk3gti
« Reply #7 on: 16 November 2013, 21:31 »
i reckon its could be the crank impulse sensor, the wires go brittle right where the wires go into the sensor and when your driving the speedo and rev counter bounce about.
Offline vwwvgolf
« Reply #8 on: 17 November 2013, 15:11 »
could that also cause the engine to cut out?
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #9 on: 17 November 2013, 18:51 »
Without doubt.
