Author Topic: Sluggish tdi130 bora 2003  (Read 4793 times)
Offline Mk2_tel
« on: 12 November 2013, 11:33 »
Basically I have a tdi130 with custom map runs fine and has done for 6months.
This weekend I gave it a oil change and filter
Air filter and diesel filter.
Problem I have is felt fine for 30miles around town but when I went to work this morning
100miles away started playing up.
When sitting at 80mph runs ok hit a slight hill starts running lumpy pushing through that and pulls to 100+
Also getting it playing up at 50-60 in 4th/5th gear.
Had new maf sensor on air box about a year ago and red x cleaner this morning to see if that helps cheers
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Sluggish tdi130 bora 2003
« Reply #1 on: 12 November 2013, 16:39 »
Are you getting any fault codes?
Also check the vacuum hoses, especially the one inside the ECU as i had the same issue with intermittent power loss especially when on full boost up hills on my 90bhp TDI and replacing the hoses resolved it.
Offline Mk2_tel
« Reply #2 on: 12 November 2013, 17:48 »
My dad has a vagcom so next time I see him ill plug it in.
And I will check hoses first thing tomorrow thanks for that
Offline Mk2_tel
« Reply #3 on: 12 November 2013, 22:09 »
What size diameter are the hoses and how many? Cheers
« Reply #4 on: 12 November 2013, 23:01 »
Im not too sure about the PD130 but the majority of the hoses on mine were 3mm ID. Silicone replacement hose on ebay was only about £1.40 ish per metre.
Offline Mk2_tel
« Reply #5 on: 13 November 2013, 09:53 »
Does it matter if I got 4mm would it affect anything?
Offline EsSeX dAn
« Reply #6 on: 13 November 2013, 21:24 »
when the engine was turned off then on again did it go back to normal? if so itll be the overboost/limp mode thing. what oil did you put in out of interet?
i think i love you.....
Offline Mk2_tel
« Reply #7 on: 14 November 2013, 08:27 »
It done same thing once turned off and on.
And correct pd oil was out in car Lucas oil
