Author Topic: EA288 2.0 TDI 184PS Development thread..  (Read 190031 times)
Offline virginVWman
Re: EA288 2.0 TDI 184PS Development thread..
« Reply #200 on: 03 August 2014, 23:39 »
I've comprehensively tried out all the settings to give Andrew my opinion on each, and as my new box is set up, 3+1 is the clear winner for driving feel, smoothness across the range, responsiveness in mid and high load, and mpg. I believe Andrew has made tweaks to the maps based on mine and a few other's recommendations, and the settings on mine in 3+1 will be the new 3+2. Being able to change the maps at the press of a few buttons rather than removing the box from the car and opening it up to make changes is very handy.
You can feel that the new 3+1 (3+2) is a bit more powerful than the old box on 4+1.
Unlike the mapping options, being able to whip this off the car in 5 mins for warranty and servicing is a real plus. Mine is in for it's first service on Monday.
If andrews made tweaks then do you think we with the old unit can have the new updated version?
Mk VII 3dr GTD in DBP
Fitted DTUK Stage 2 (CRD-T)
Offline Rick101
« Reply #201 on: 04 August 2014, 04:18 »
Does the new package sit in the same location as the last one?
How much longer does it take to fit?
I see it's easier to change maps, but why would you want to? Surely better to leave it on the best setting (3+2?).
-----------------------Edit
DOH - Ignore me, it's all there for me to find!
1. Looks to be same part as the old unit, with extra functions (I thought it was a additional new part you fitted in the cabin)
2. Should take the same amount of time to fit, see point 1!
3. You can change maps to suit your driving style
Let me know if i've misunderstood and posted some fibs.
« Last Edit: 04 August 2014, 04:27 by Rick101 »
Offline monkeyhanger
« Reply #202 on: 04 August 2014, 07:58 »
It's a slightly smaller box, fitted in the same way, in the same place. No reason why the old box shouldn't be able to get new box 3+2 (3+1 on mine as it's currently set up) settings with a reprogram, the increments on the fine tuning need to be altered from 75mV per increment on old box to 50mV on the new one so you can do old map 4 +100mV.
Just drove my car to it's first service with no box on and no Miller's in the tank. 46mpg for a 23,mile journey....very poor. Can't wait to put the box back on.
« Last Edit: 04 August 2014, 08:00 by monkeyhanger »
Offline stuart.cameron
« Reply #203 on: 04 August 2014, 10:24 »
Can I exchange my old box for a new one?  :rolleyes:
Current // Golf GTD 3dr DSG - Carbon Grey | Discovery Nav Pro, Keyless Entry, Park Assist, Reverse Camera, Winter Pack
Previous // Polo GTI 6r - Black | Xenons, MFSW, Winter Pack, Sensor Pack, Convenience Pack, Climate Control, RNS 510 w/Bluetooth
Offline Rick101
« Reply #204 on: 04 August 2014, 18:45 »
Finally ordered one today. Glad I delayed tbh as I having the latest model is a bonus. :smiley:
Offline Rick101
« Reply #205 on: 05 August 2014, 13:15 »
Just fitted :smiley:
Tried to ring earlier to check I'd done it correctly but lost signal, sorry about that.
Nice upgrade and I feel worth the money. I wouldn't say it turns the car into a properly fast car (i've been spoilt), but it does give a good bit of extra oompf in the midrange. I don't think it's a substitute for petrol but it does make it an incredibly fast diesel. Maybe I need to play with it more to get the most out of it. Set box to P3+2 and drove car in Sport and Normal, def helpful for overtaking!
As has been said, fairly easy to fit. I took some pics just incase I made a mistake but thankfully didn't. Posted below as reference for others.
Delivery arrived, next day service :smiley:
What's in the box. CRDt unit, cabling, blanking plate, 2 cable ties, detailed instructions and invoice.
Switch car completely off for 5 min before starting.
Open bonnet and you'll find this - Plastic cover simply pulls off in each corner
Locate sensor #1 - it's in the 9 o'clock position with some wires going into it. Very fiddly to remove as you can't see the clasp underneath.
If you look at the coolant sensor, it's the same design. Easy to practice removal using that one but don't forget to reconnect it!
Locate sensor #2 - Much easier access to this one
The CDRt cable has numbered ends. Install 1 on 1 and 2 on 2.
The connectors sit inbetween the original sensor so you should have nothing left open at the end
Both sensors fitted and loose end connects to control box
A tidy up of cabling. I have gone to back of engine and then down alongside airbox
This is the time to test the unit and check there are no electrical errors
If all seems good, add your cable ties, locate your control unit and replace the plastic cover.
Now time to go for a drive :smiley:
« Last Edit: 05 August 2014, 13:38 by Rick101 »
« Reply #206 on: 05 August 2014, 13:24 »
Just taught a Civic R type (2013) a lesson in humility on the A19.  :whistle:
Offline lostalot
« Reply #207 on: 05 August 2014, 14:08 »
Hi guys i have just joined the site so hello everyone .
My gtd came friday and im so pleased with it.i have been reading this thread for a bit now and i will be passed the 2k mark by the end of next week.
Sorry Andrew but i cant find the pm button  when do you launch this new box ???
Andy_cs
« Reply #208 on: 05 August 2014, 14:51 »
Would really like one of these boxes but i'm still concerned about insurance, what sort of premium increases are people seeing and any problems with particular companies, I'm currently with Aviva?
Thanks, Andy
« Reply #209 on: 05 August 2014, 15:06 »
You need 10 posts before you can PM anyone.
