Author Topic: Engine warning light P2015 DTC  (Read 7548 times)
Offline mbradbrook
« on: 04 November 2013, 20:12 »
Evening all,
The engine warning light appeared on my dashboard on Saturday after starting accompanied by a lumpy idle. The car drove normally and the light disappeared after repeated starts. I have just fitted a bluefin so was concerned that this was something to do with it. Anyway the light reappeared again tonight and I used the bluefin to find the fault code - p2015 manifold intake flap. I've cleared the fault code and the light has stayed off. Do you think this is related to the bluefin or is just coincidence? The car is out of warranty so do you think vw will cover the cost to replace the manifold? Will the fact I have a bluefin fitted affect a goodwill payment from vw?
I love the car but it has been so unreliable:
New water pump
New turbo
New turbo intake pipe
New brake servo
Any advice gratefully received!
Matt
Offline Snoopy
  • Moderator
  • Geoff.
Re: Engine warning light P2015 DTC
« Reply #1 on: 04 November 2013, 20:19 »
I have heard of this fault been more common after a remap but its not caused by it.
This is a known fault and been talked about a few times on here.
I would not mension the bluefin if you are after a good will payment and getting it fixed at the stealers.
You definitely have been very unlucky as you have had all but 3 of the common issues with these cars.
« Last Edit: 04 November 2013, 20:23 by Snoopy »
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline RocketRossUK
« Reply #2 on: 04 November 2013, 20:55 »
Evening all,
New water pump
New turbo
New brake servo
Matt
Wow that is a lot of things to go wrong, have you had it from new or were you a second owner?
Offline mbradbrook
« Reply #3 on: 05 November 2013, 17:54 »
I was the 2nd owner but the car was in immaculate condition.
I've now booked the car in to vw. Just out of interest, i've cleared the fault code and the light is off but will the dealer still be able to see the previous fault code or will it have been wiped off?
Matt
« Reply #4 on: 05 November 2013, 17:57 »
Matt
Sounds like the previous owner ragged it to bits, or just hammered the Turbo.
Did you save the fault code before wiping? if not it may be gone as my VAGCOM doesnt see it when they have been wiped.
Offline mbradbrook
« Reply #5 on: 05 November 2013, 18:06 »
To be fair the turbo was replaced due to an oil leak which actually turned out to be the turbo inlet pipe leaking. All uner warranty so wasn't bothered at the time.
Hopefully the light will come back on and I'll just leave it.
Offline Rgdogg
« Reply #6 on: 05 November 2013, 18:22 »
Mine did the same when I installed the bluefin, same code I reset it but it came back, new inlet manifold required, think they quoted about £670 but it was fixed under warranty.
Gti, Candy White, 3door, DSG, Leather, Rear LEDs, Bluefin, Milltek, vwr intake, Focal speakers.
Offline mbradbrook
« Reply #7 on: 05 November 2013, 18:25 »
Wife is blaming it on the Bluefin!
Offline Rgdogg
« Reply #8 on: 05 November 2013, 18:38 »
I thought it was to blame at first, really crap design when you see it, it's only the flap but you have to replace all of it.
« Reply #9 on: 05 November 2013, 22:05 »
