Author Topic: downpipe rattles !!!!  (Read 2202 times)
Offline AD1.8T
« on: 04 November 2013, 14:25 »
First thing sorry all for the multiple threads the last couple of days !
Now my decat is finally on but yuuuup you guessed it its now vibrating like man I can see where its resting so I tried something knowing my dogbone mount is abit tired I jacked up the car the put another jack under the front bolt on the dogbone. I only done 2 or 3 pumps on the jack and it gave me just under an inch clearance!
So if I replace my dogbone mount should it cure the problem ?
Also I think I know whats wrong but since doing the decat and catch can my car smokes real bad (white) but I believe this is because I left the mid section outside last night and it rained as I did poor abit of water out of it this morning :/
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: downpipe rattles !!!!
« Reply #1 on: 04 November 2013, 18:42 »
I had the same problem when mine was fitted years ago mate, new dogbone cured the problem
Offline AD1.8T
« Reply #2 on: 04 November 2013, 18:47 »
Nice one cheers buddy mine is foobard to be fair I did put the poly bushes in well over a year ago but they were horrendous!! I dont really want to pay £90 odd for a r32 one, would a lemforder one from ecp be ok £40 is alot more appealing lol
Offline Scott D
« Reply #3 on: 04 November 2013, 19:36 »
I would go for an R32 mount or genuine OEM.
Can't comment on Lemforder but I had dogbones from THS & ECS which I assume are based on cheaper non OEM mounts - both failed in less than 12 months, smaller bush excessively worn in both cases.
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 04 November 2013, 19:37 »
I bit the bullet and got the R32 one all those years ago.
Offline AD1.8T
« Reply #5 on: 04 November 2013, 20:02 »
Hmmm maybe after xmas then, my mrs goes overboard around xmas and its never good for the wallet !
Offline brewey
« Reply #6 on: 04 November 2013, 23:16 »
If she goes over board whack it on your list ;) save buying one yourself.
I was going to buy a second hand dogbone and poly bush it but after reading this maybe r32 is the way to go.
2000 1.8T ARZ - OEM+
Offline AD1.8T
« Reply #7 on: 05 November 2013, 07:03 »
Obviously its all down to preference mate but I advise not to polybush I used the (I use this term lightly) "softer" red bushes and it felt/sounded like I had a bulldozer behind the dash !
Offline Rhyso
« Reply #8 on: 05 November 2013, 08:19 »
R32 mount FTW
Ven fitted to my old Golf it was nice and quiet yet still able to handle the torque
Offline mcgee9t2
« Reply #9 on: 05 November 2013, 12:40 »
i have pollybushed mine.
know what everyone means about the vibrations etc. but soon get used to it.
