Author Topic: Still have issues  (Read 2088 times)
Offline Dalo Harkin
Still have issues
« on: 01 November 2013, 10:36 »
Hi guys,
I was having an issue with blue smoke which seemed to now go away.
I was out in it last night as it was low on oil so I did a new filter, new oil replacement which was due anyway.
Anyway, I have noticed now that there is no smoke, but the car is massively underpowered, its stage 2 K03s and seems worse than my K03 was on a stage 1.
I did the usual checks - cant see any boost leaks, doesn't seem to be any better when the MAF is unplugged etc.
Scanned for codes and found no faults....
Does anyone else have any ideas I can try?
Offline houston
Re: Still have issues
« Reply #1 on: 01 November 2013, 19:45 »
Blue smoke = oil
Get a compression test done on the engine to be on the safe side,  but I would be guessing that its more likely the oil seals have gone on the turbo
Offline Dalo Harkin
« Reply #2 on: 04 November 2013, 12:53 »
compression is fine according to the garage  :undecided:
So am I looking at turbo out and a rebuild before I even know it that's the issue? any other suggestions from anyone?
Offline houston
« Reply #3 on: 05 November 2013, 00:30 »
You can pick up a k03s quite cheap, whip off the turbo pipes, hot and cold side, if the seals have gone it will be obvious
Offline Dalo Harkin
« Reply #4 on: 06 November 2013, 16:10 »
but surely if the seals were gone it would always blue smoke?
The blue smoke has gone now, in the other thread I made, I mentioned the car had been stood a little while and then did a 200 mile round trip and it was fine then I went out a few days later and there was a bit of blue smoke on start up and then it went.....
I'm just experiencing a loss of power now and the car isn't boosting as much as it used to
Offline MoshiMoshi
  • Scorpion Exhausts are delightful.
« Reply #5 on: 07 November 2013, 20:45 »
Just an idea, but valve stems? If oil is pooling and being burnt off on startup I guess that could make sense? I don't know the steam sealing on these heads but my old Escort used to burn a lot of oil owing to a few knackered stem seals.
I thought Volkswagens were supposed to be reliable?
Offline Dalo Harkin
« Reply #6 on: 17 January 2014, 12:26 »
Im going to be trying to solve this tomorrow, going to remove the TIP at the turbo end to see what state the wheel is in and then ill try the basics, swapping all the plugs and testing again, removing the MAF and go from there
Offline Dalo Harkin
« Reply #7 on: 18 January 2014, 10:43 »
So did all I said I would, couldn't notice anything untoward so thought I'd take it down the road, left the car on the drive a good 15-20 minutes on tick over to get warm first.
So was driving slowly, no new noises, booted it a bit and a cloud of white smoke from the exhaust and the cat was shuddering like a coil pack had gone down, any ideas? Fooked turbo ? :cry:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 18 January 2014, 11:05 »
white is steam , this doesn't sound well...
Offline Scott D
« Reply #9 on: 18 January 2014, 12:51 »
I had white smoke when the K04-001 had cracked allowing coolant in, smoked quite a bit on idle and when booting it.
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
