Author Topic: For those with Wellycoolers or 2.5" pipework.  (Read 3095 times)
Offline Dave_IOW
« on: 31 October 2013, 11:14 »
What did you connect the take off for your n75 from? I have the standard bit of tube which has the nipple on it, but it's only a 2" bore.
Looking to get the k300 from Littco some time next year and want full 2.5" intercooler piping.
I'm guessing you have bought a 63mm silicone T for the DV?
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
jamie16v
Re: For those with Wellycoolers or 2.5" pipework.
« Reply #1 on: 31 October 2013, 14:16 »
you can either weld a nipple into the first section of alloy pipe or, what I did was take it direct from the manifold.
you might think you can`t do this, but you can  :smiley:
I believe the T for the DV is usually done in hard alloy.
Should have kept your mk4!
« Last Edit: 31 October 2013, 14:25 by jamie16v »
Offline EsSeX dAn
« Reply #2 on: 31 October 2013, 18:18 »
Can someone enlighten me plz, what on earth is a wellycooler? ive googles it but it just looks like an intercooler to me? does it go between the air filter and maf sebsor or something? plz dont rib me too much lol
i think i love you.....
jamie16v
« Reply #3 on: 31 October 2013, 20:33 »
it`s a refrigerator for your wellington boots!
on a serious note, its just a big intercooler from ebay.
Offline EsSeX dAn
« Reply #4 on: 31 October 2013, 22:48 »
haha nice answer. ahh i see i see. sorry to hijack by the way!
Offline Dave_IOW
« Reply #5 on: 01 November 2013, 00:15 »
Cheers Jamie :afro:
Had thought about the feed coming off the manifold to be honest, seems a hell of a lot easier!
Also thought about using those silicone taps but was worried about leaks.
Regarding DV, trying to use as much hard pipe as I can, going to use the silicone T piece and use that as a joiner, might aswell make one of the joins useful!
If I kept my mk4, I could have had rods and a GT2871r by now :sad: :grin:
Offline Dalo Harkin
« Reply #6 on: 01 November 2013, 10:03 »
This is one of the reasons I copied the way the S3/TT setup is, I used the charge pipe and the inlet manifold off an S3/TT and just adjusted the piping layout to suit
Offline Dave_IOW
« Reply #7 on: 01 November 2013, 17:03 »
Not much good on AGU unfortunately pal, manifolds different.
Also going in a mk2, unsure if a BAM charge pipe will fit down the side..
Think I've pretty much worked it out now :smiley:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 01 November 2013, 17:58 »
Me and Mike just worked it out too lol
Offline Dave_IOW
« Reply #9 on: 01 November 2013, 18:02 »
 :huh:
What's that cheeky lil chap just been round? Don't tell me you get Eslanade delivery!!!  :grin:
« Last Edit: 01 November 2013, 18:19 by Dave_IOW »
