Author Topic: Front brake hose fit golf GTI 8V 1992  (Read 7026 times)
Offline caprigreen
Re: Front brake hose fit golf GTI 8V 1992
« Reply #20 on: 31 October 2013, 10:32 »
Right, crappy picture but this is an ATE hose and it's flat at the end with a smallish hole....
This is a Meyle hose, concave at the end with a large hole...
Ben your a star ! the ATE Looks the one , I will give you a ring at Heritage can you deliver next day ?
64 plate VW Golf GTI PP Pure white
1991 VW Golf GTI 8v Silver, 30k miles
Offline caprigreen
« Reply #21 on: 31 October 2013, 11:07 »
Hi Ben tried to phone you but you were busy. I spoke to one of your colleagues who says there is only one hose available and that it would take a cpl of months to look into the issue with suppliers. The Meyle one has the same part number but as you can see is different fit. Not sure where to go from here and thoughts ?
Offline Gambit
« Reply #22 on: 31 October 2013, 12:49 »
nice one Ben@VWH - cant get better service than that!!
Offline Ben@VWH
« Reply #23 on: 31 October 2013, 16:56 »
Sorry capri green, i've been out on the road this afternoon. From what I can see by looking at a caliper we have on the shelf here, the actual sealing of the hose comes from the small tapered edge around the outside of the the hose end (and the fine thread itself helps seal). Therefore it shouldn't technically matter which hose you fit, I would suggest fitting a matching pair just to ensure you don't get a brake imbalance.
Tis a shame we only had one ATE hose left though.
Offline caprigreen
« Reply #24 on: 31 October 2013, 18:21 »
Hi Ben, thanks for taking the time to help. I have obtained the correct hoses from Eurocarparts they are the same fitting as the ATE and made by pagid. I have discussed again with the garage and they are of the opinion that the the difference is essential for them to fit? I have not seen the caliper so cant explain more at the moment so will reserve judgement.
 I have run a check for a 1990 gti with eurocarparts and that shows the same part number as my 1992 so it may well be that both hoses will fit. If that's the case then I just wonder why they have slightly different fittings? If it was not a potential safety issue I would not be looking in so much detail.
Thanks Ben ,  to all who have assisted me
Regards Steve
Offline Gambit
« Reply #25 on: 31 October 2013, 19:35 »
Fit them. If they dont seal then they wont be able to bleed them so you wont actually have to drive to test
the likes of goodridge braided hoses only do one type for mk2 golf gti's for all caliper types, the only difference in factory hoses is the length of hose on front calipers
VW BUSH
« Reply #26 on: 31 October 2013, 19:49 »
The relief on the tip gives you more contact pressure so should seal off easier than trying to seal over a bigger land.
It will also take a compression fitting to hard pipe hence the bigger hole, just a std hydraulic fitting :smiley:
Offline caprigreen
« Reply #27 on: 31 October 2013, 21:25 »
Good point Gambit.
Thanks VW Bush , that makes sense, looks like I have made a fuss over nothing, but got there in the end thanks to you guys.
Offline Ben@VWH
« Reply #28 on: 01 November 2013, 10:01 »
At least it's all sorted now!  :smiley:
Offline caprigreen
« Reply #29 on: 01 November 2013, 22:48 »
Thanks Ben I appreciate your help
