Author Topic: Fitting Coilovers Tonight (Hopefullly)  (Read 1964 times)
Offline Shizzle
« on: 29 October 2013, 08:06 »
Hey thanks to Khare my new (used) coilovers should be here today i Just want to know do i need any special tools is there a quick method i am also changing front top mounts to powerflex bushes new nuts and new bearings.
The suspension has been changed/tampered with previously so hoping no stuck rusty bolts is there anything i should know about this swap????
MK3 Golf GTI 2.0 16v 3Door Storm Grey
Offline bigberty101
Re: Fitting Coilovers Tonight (Hopefullly)
« Reply #1 on: 29 October 2013, 09:25 »
sounds like you have it all covered, just remember to copper ease the f**k out of the threaded shock body to avoid the lock rings seizing. and before you loosen off the camber bolts / shock bolts to hub, score where the shock meets the hub with a screw driver / Stanley knife / mark with tippex pen so you know where to put the new shock so the camber of your wheel isn't out. and get your tracking / camber angles checked after
Offline Shizzle
« Reply #2 on: 29 October 2013, 09:27 »
So can you adjust the rear camber this way for more negative camber?
Offline Callum_K
« Reply #3 on: 29 October 2013, 09:33 »
No only the front.
Offline Shizzle
« Reply #4 on: 29 October 2013, 09:35 »
Ok i have a 4 wheel alignment machine at work il get it on that next few days once suspension has settled thank you for quick reply will post photos when done.
Offline bigberty101
« Reply #5 on: 29 October 2013, 10:46 »
could take more than a few days to settle, mine took almost 2 weeks. to adjusted the rear camber its done though spacing the lower half of the hub out, using camber shims, do a quick search
« Reply #6 on: 29 October 2013, 10:47 »
Being used they will not take long to settle.
Offline Shizzle
« Reply #7 on: 29 October 2013, 10:53 »
Well only if my tracking is out i will get tracking done sooner rather than later but if it drives ok i will leave it for a week before i do the alignment.
Offline bigberty101
« Reply #8 on: 29 October 2013, 12:44 »
sweet, mines a daily and used it for around a 30mile commute = whatever in the evening, saying that thou, mine are cheap crap
Offline Shizzle
« Reply #9 on: 29 October 2013, 14:31 »
well my journey to work is  0.8 miles i live on same road very handy if i low on fuel just get on my bike but saying that i drive to work everyday  :whistle:
