Author Topic: Passenger Window Won't Go Down  (Read 1639 times)
Offline Shady Pioneer
  • graphic designer.
« on: 26 October 2013, 01:12 »
As per the title really. My passenger front window was working just fine until tonight where when I put it up and tried to have it down again, there was a loudish noise and I could hear the motor doing its thing but the window remained up.
When pressing the switch up and down I can hear it doing its full movement as if the window was in.
Is this a simple fix or a ballache? I'm guessing the window has come free from the runner or something?
It's worth noting I installed wind deflectors yesterday, is it possible that the window has latched into that?
Offline Rhyso
Re: Passenger Window Won't Go Down
« Reply #1 on: 26 October 2013, 10:33 »
Could have a broken window clip and you got lucky it got jammed in the closed position
Whip off the door card and remove the rubber inspection cover for a better look
  • graphic designer.
« Reply #2 on: 26 October 2013, 12:08 »
Just inspected it further and turns out it was lodged away from the runner.
Held in in place and pushed down whilst pushing the window down button and it went back into place.
I removed the wind deflector to see if it is that and sadly it is.
Offline Rhyso
« Reply #3 on: 26 October 2013, 17:05 »
How rude  :sad:
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #4 on: 26 October 2013, 22:22 »
Least your sorted shady easy fix :afro: i guess a pair of wind deflectors could be up in the classifieds  :grin:
2000 Mkiv GTi 1.8T AGU
  • graphic designer.
« Reply #5 on: 26 October 2013, 22:48 »
I'm trying to get a refund from the seller first, if not then yes.  :laugh:
Offline dom
  • Back in a Mk4
« Reply #6 on: 27 October 2013, 00:03 »
Try tightening the clip that holds the glass first  :wink:
  • graphic designer.
« Reply #7 on: 27 October 2013, 00:07 »
I'll be honest, I've looked at tutorials for the window clips and it looks like it's fiddly.
Plus I would be better getting metal clips to replace the "poor" plastic clips.
Offline dom
  • Back in a Mk4
« Reply #8 on: 27 October 2013, 00:09 »
Is there not just a screw on the clip to tighten in? Mine now has metal ones and they do
  • graphic designer.
« Reply #9 on: 27 October 2013, 00:34 »
In all honesty I haven't had a look but assuming the ones I have are plastic surely tightening the screw will only cause it to fail sooner by adding extra stress to it?
I can live without deflectors for now. Assuming I can get a refund, if not I may look into replacing the clips with metal ones and ensuring a decent fit.
