Author Topic: Help help help  (Read 4519 times)
Offline Gapper10
Help help help
« on: 23 October 2013, 14:53 »
Need some help!!! Removed intake manifold on 16v as had some shot wiring made a new wiring harness last week that goes to throttle bodie. Installed intake manifold today went to connect the two seperate plugs to the throttle bodie and have a plug spare. So that leaves me with two connected and on not and I might be stupid but I can't seem to see where it goes... Help me please befor I set it on fire
Offline Shizzle
Re: Help help help
« Reply #1 on: 23 October 2013, 14:56 »
Can you get a picture of the plugs?
MK3 Golf GTI 2.0 16v 3Door Storm Grey
Offline Ben@VWH
Re: Help help help
« Reply #2 on: 23 October 2013, 14:59 »
I imagine the three plugs you have are.
-3 pin plug- this goes to the throttle body potentiometre.
-2 pin plug- this goes to the idle switch on the throttle body.
-2 pin plug- this goes to the crankcase breather heater - if you look carefully at the plug on the breather pipe, the connector doesn't even have pins. It's for colder climate models only.
Offline Gapper10
Re: Help help help
« Reply #3 on: 23 October 2013, 15:15 »
where is the crank case breather heater located?
Offline Shizzle
Re: Help help help
« Reply #4 on: 23 October 2013, 15:23 »
if i am correct it the small breather that runs inline with induction pipe and goes to front of engine located between induction pip and engine. there is a rectangular connection just and empty space that connection plugs into.
Offline Gapper10
Re: Help help help
« Reply #5 on: 23 October 2013, 15:26 »
« Last Edit: 23 October 2013, 15:27 by boneybradley »
Offline boneybradley
  • Back in a Mk3...
Re: Help help help
« Reply #6 on: 23 October 2013, 15:27 »
Offline Gapper10
Re: Help help help
« Reply #7 on: 23 October 2013, 15:28 »
cheers il have a look and get back to you i hope your correct thanks again
Offline Gapper10
Re: Help help help
« Reply #8 on: 23 October 2013, 15:35 »
[imghttp://][/img]
Offline Shizzle
Re: Help help help
« Reply #9 on: 23 October 2013, 15:37 »
they look like the plugs you need the 1 you cant find a place for is  defiantly that breather pipe  :smug:
