Author Topic: Help help help  (Read 4520 times)
Offline Gapper10
Re: Help help help
« Reply #10 on: 23 October 2013, 15:40 »
they look like the plugs you need the 1 you cant find a place for is  defiantly that breather pipe  :smug:
You my friend are a legend  :grin: thats gotta be the worst place to put a non needed plug
Offline Shizzle
Re: Help help help
« Reply #11 on: 23 October 2013, 15:55 »
Ben@VWH was the most helpful, knowing what plugs you had i just knew the location glad i could help.
MK3 Golf GTI 2.0 16v 3Door Storm Grey
Offline Ben@VWH
Re: Help help help
« Reply #12 on: 23 October 2013, 16:14 »
 :smiley:
Offline Gapper10
Re: Help help help
« Reply #13 on: 23 October 2013, 20:44 »
Cheers Ben much appreciated  :smiley:
Offline Gapper10
Re: Help help help
« Reply #14 on: 24 October 2013, 14:30 »
Still on this topic got car back together last nite but it won't idle cold and it won't start with out giving it gas hot or cold.... More help needed getting to the end of my tether :angry:
Offline bigberty101
Re: Help help help
« Reply #15 on: 24 October 2013, 15:09 »
is the isv working? turn ignition on and touch it, should hum / buzz a little. clean inlet, check vaccum lines to ecu map sensor, brake servo, carbon canister, check blue ecu temp sensor is working,
Offline bigberty101
Re: Help help help
« Reply #16 on: 24 October 2013, 15:11 »
had the same issue with mine, turned out to be an wiring fault and kept blowing fuse 15, check that, that controls the isv, blew fuses when wires were shorting, just another option to try
Offline Gapper10
Re: Help help help
« Reply #17 on: 24 October 2013, 15:16 »
It give it a go cheers
Offline bigberty101
Re: Help help help
« Reply #18 on: 24 October 2013, 15:52 »
no worries, let me know if you need anything because ive got all the info at home about fuse 15, looms, diagrams etc
Offline Gapper10
Re: Help help help
« Reply #19 on: 26 October 2013, 17:13 »
cheers for the help got the car running last nite fuse 15 had gone  :grin:
