Golf mk2
Can you remove the upholstery / covers off mark 2 golf seats?
Topic: Can you remove the upholstery / covers off mark 2 golf seats? (Read 1866 times)
dasachmo
21 August 2005, 17:44 »
hi, i got a new mk 2 golf seat, coz my old one was broken, and the new one is filthy, im just thinking, it was just teh frame that was broken on the old seat, so is tehre any way in which u can remove the upholstery from the old one and put it on the new one?
...joe
Forum Supporter
Forum addict
Re: Can you remove the upholstery / covers off mark 2 golf seats?
21 August 2005, 23:00 »
yes. bit fiddly but do-able.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
dubslug
21 August 2005, 23:33 »
helpfull as ever joe lol
1992 pearl grey 8v
...joe
Forum Supporter
Forum addict
21 August 2005, 23:55 »
hey man i try my best! its hard to describe how to do it, you just have to work your way round pulling off relevant clips etc undoing things. easier to do than describe.
Organisys
Old and Slow...
22 August 2005, 13:26 »
ok, so i might try to fix up the bolster and frame a bit on my drivers seat. Removing the seat is not a problem, but where would you suggest starting with removing the cloth please? any one corner/seam a good place to start?
Quote from: Mr Blue on 29 May 2013, 19:15
Mr Blue
Forum addict
22 August 2005, 13:33 »
first off remove the side covers. there are 3 little pins you need to push in and then it clips off. You can remove the top half of the seat at this stage by the screws or wotever
turn the seat over and you need to stretch the cloth and unhook it from the metal hooks (might need to bend the hooks)
then at the back underside you just pull the folded cloth out and the rest should be easy to figure out.
Like Joe said its hard to explain. I did this to my seat and the foam bolster was badly worn. VW charge £60 for a new foam but i was thinking of takng one from a passenger seat as they are more firm or cutting out my own foam
Blue
Last Edit: 22 August 2005, 13:36 by Bling Blue Mk2
dasachmo
Reply #6 on:
22 August 2005, 13:43 »
cheers blue, i bought a new seat, and the cloth werent as good as my old one, and if i swap the covers , then at least i can keep the upholstery matching with the rest of the car, WILL DEF GIVE IT A TRY
Golf mk2
