Author Topic: KERBSIDE MIRROR SETTING  (Read 6567 times)
Offline harryhackenbacker
« on: 22 October 2013, 17:11 »
Well after setting up almost everything ,can't set the Kerbside Mirror View to work in reverse , ,nor can a VW senior
Techo or a few people In between .
Not sure if it's related to extras fitted or what !!!!  Tech Request sent to VW  unless anyone has had the same
problem ,with DSG/ Rear Camera / Keyless / and the other bits !!! would love to hear if anyone is the same  :wink:
MK7 R 3 DOOR DSG PEARL BLACK FULL SPEC CARBON
LEATHER
Offline monsta
Re: KERBSIDE MIRROR SETTING
« Reply #1 on: 22 October 2013, 17:13 »
I believe it has something to do with the electric mirror adjustment switch?  Have you tried setting it so a mirror is selected (i.e. as if you were about to adjust the mirror's position) whilst reversing?
Offline GolfTi
  • ..gotta feel for my automobile..
« Reply #2 on: 22 October 2013, 17:19 »
It needs to be on L.
Mk7 GTI. DBP, DCC, Winter pack. Mine since new, July 2013.
GTI no. 4. Golf no. 5.  VW no. 7.
« Reply #3 on: 22 October 2013, 17:24 »
On L when reversing , think we covered that ,but I will check again ,thanks .
LEATHER
Offline GolfTi
« Reply #4 on: 22 October 2013, 17:47 »
If you haven't already then try setting it.
Put car into reverse, move L mirror to required position.
Leave mirror setting on L.
It should reset when you drive forwards at a certain speed.
Mine hardly moved when I first got it, like you I thought it wasn't working.
Offline Torch
« Reply #5 on: 22 October 2013, 17:50 »
A bit more help if I may -
You also need to go into the infotainment system in settings to tick the box so that the left hand mirror obeys the command
Regards
Offline JohnP
« Reply #6 on: 22 October 2013, 18:03 »
Mine was the same when I got it until I found out you set the mirror where you want it to be when you reverse
« Reply #7 on: 22 October 2013, 20:59 »
Much appreciated Guys ,I will take another run at it tomorrow ,and report back  :smiley:
LEATHER
Offline p3asa
« Reply #8 on: 23 October 2013, 08:39 »
When I got my car some joker set mine to point up the way at the sky when I selected reverse  :huh:
Initially I thought it was broke but after figuring out how it works, I soon sorted it.
« Reply #9 on: 23 October 2013, 11:40 »
No Go Guys , tried loads of different ways ,so it's wait for a VW tech update now  :wink:  Thanks for the Input  :smiley:
LEATHER
