Author Topic: Scratching my head now  (Read 1008 times)
Offline northeast_gti-t
  • "1.8T AGU"
« on: 19 October 2013, 08:34 »
Think i need to look up a mk4 wiring diagram of sorts  :huh: all this bother for an indicator flash on locking the car i have hooked up vag com this morning and its thrown up these codes,one or two i'm not fussed with but some how its thrown up a r/h rear door module fault  :huh: how come as mines a 3 door,also im wondering if there might be a prob on the door loom as i remember when i removed the multi plug i found that pin 8 had snapped and was corroded in the multiplug side (hence my o/s door mod fault i assumed) i managed to remove most of the pin if not all but would this effect the new module the plug went back on okay tho..
16525-oxygen(lambda)sensor B1,S2:heating circuit malfunction P0141 - 35-00
16556-fuel trim B1 system to rich P0172 - 35-00
01334-door control module:rear right(J398) 49 - 00 - no communications
01135-interior monitoring sensors 49 - 00 - open circuit
00944-heated exterior mirror: passenger side(Z5) 35 - 00 -
been on ross tech and the codes im wondering about are 01334 and 01135 not fussed with the other 3 atm only had all these since replacing both door modules  :laugh:
2000 Mkiv GTi 1.8T AGU
Offline golfyste
  • Project track car
Re: Scratching my head now
« Reply #1 on: 19 October 2013, 18:30 »
Surely you should be more bothered about your lambda/fueling issues then the rear door module  :laugh:
  • "1.8T AGU"
« Reply #2 on: 19 October 2013, 22:53 »
Done some work today and all fault codes gone  :wink:
