Author Topic: Indicator flash on locking **Sorted***  (Read 3492 times)
Offline northeast_gti-t
  • "1.8T AGU"
« on: 17 October 2013, 21:11 »
Finally managed to sort my locking faults out  :smiley: bought and fitted 2 new door modules and now have,puddle lights,lights on chime and all interior lights working as they should,my only problem is on unlock the indicators flash twice as they did but on locking there is no indicator flash alarm led lights up as normal tho,now i have read a few things about this and have taken the bonnet microswitch out and re-cleaned etc disconnected the multi plug and locked the car with the fob still no flash,so had a quick look on my shareware version of vag-com and been into
46 Cent Convinience and gone into adaption values and it seems channel 08-lock-turn signals flash is switched on! looking for some help please as i'm now a little stumped as to why no conformation flash :huh:
Also just to add i fitted a new bootlatch last week as the old one was broken so the bootlight works now also,so somehow something is telling the system somethings open?
« Last Edit: 20 October 2013, 15:46 by northeast_gti-t »
2000 Mkiv GTi 1.8T AGU
Offline Adam
Re: Indicator flash on locking **help***
« Reply #1 on: 17 October 2013, 21:35 »
Correct me if i'm wrong but you cant do any adaptions and save them on the free version of vag com/VCDS
Down Hill From Here.
  • "1.8T AGU"
« Reply #2 on: 17 October 2013, 21:54 »
that's what i thought adam i managed this when i had my 1.8t but this one tells me i need a registered version to change adaption values  :laugh:
Offline Tezmax
« Reply #3 on: 17 October 2013, 22:50 »
Is this something you want to change or should they flash when locking as mine dont?
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
Offline Rhyso
« Reply #4 on: 17 October 2013, 23:13 »
They flash once when you lock the car
Offline Bellend
« Reply #5 on: 17 October 2013, 23:35 »
I can do windows roll up and down too on the Passat and MK4, dunno if its VAG-COMable on the MK4 but its not on the B5.5
Where all my moneys went.
  • "1.8T AGU"
« Reply #6 on: 19 October 2013, 08:00 »
I wish mine did  :lipsrsealed:
  • "1.8T AGU"
« Reply #7 on: 19 October 2013, 08:09 »
Had a look at the relay plate under the steering wheel as its been mentioned these can cause an issue found the two 15amp fuses and both were okay  :undecided: so removed both and locked no flash on lock or unlock,re-fitted the rh side fuse and tried again no lock flash and the usual unlock flash tried the other way round and same result only an unlock flash.
Offline scottv6
« Reply #8 on: 19 October 2013, 19:05 »
I have the exact same problem mate,and I have full payed up vag com.  if you find the answer let me no and vise versa  :smiley:
  • "1.8T AGU"
« Reply #9 on: 19 October 2013, 23:14 »
Glad i'm not alone then  :grin:
Well i managed to get a payed up version today so re-scanned and after some more searching i found that my new ccm module (exact part as old one)is coded for a 4 door/power windows model,so i re-coded mine with correct code for a 2 door/power windows model now have no codes  :smiley: so enabled auto lock/un-lock,horn beeps on lock/un-lock i  still have no flash or beep but this led me onto my bonnet catch/switch which is i find to be problematic so i tried this taken from a post on uk-mkiv's :
found out a little something for people that dont have a beep for when they lock
lock your car with the driver window open and pop the bonnet if the alarm doesnt go off you may be on to something
lift your bonnet with the car still lock and you will see inside the latch at the bottom middle a little sensor with a switch on the top try bushing that down and see if you get a bleep or set the alarm off
if it does it's faulty next try unlocking the car push the switch down and lock the car and if you beep you know what you need to change Cool
hope this help Big Smile
pretty sure my microswitch is faulty plus my catch has to be loosened to lock the bonnet,so will be ordering a new catch/loom assembly from vw i hope this solves it  :rolleyes:
