Author Topic: Where to start before Map ?  (Read 1161 times)
Offline luke20
« on: 16 October 2013, 23:27 »
Purchased a Golf Gti Y Reg 1.8t I want to get this Mapped at Rtech but need to have my car running spot on to do that but don't know what I need to do/change? any help would be great thanks
Offline Nino
Re: Where to start before Map ?
« Reply #1 on: 17 October 2013, 07:23 »
Main thing you need to do is getthe car scanned and make sure there is no error codes. If tou have codes mostly likely will be 17705 this is a boost leak and beileve me its a pain to find.
If you havent got any codes id personally advise at a bare minimum you change you diverter valve for an upgraded one id advise ether a forge 007p or a forge 008.
If you wanted to be extra safe id upgrade  all your boost pipes to silicone to avoid any possible splits. :)
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline Lewy
« Reply #2 on: 17 October 2013, 11:23 »
^ Before any of that, ensure it's been serviced properly to give you a good base.
Offline mrsaunders
« Reply #3 on: 17 October 2013, 12:16 »
I wouldn't worry about getting a new DV, I read on Nikki at Rtechs fb page that the standard one is more then capable
Offline Nino
« Reply #4 on: 17 October 2013, 14:49 »
+1
Offline Nino
« Reply #5 on: 17 October 2013, 14:49 »
Yes but they are well known for commonly failing ;)
Offline Scott D
« Reply #6 on: 17 October 2013, 21:52 »
smoke test for any boost and vacuum leaks
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline Tezmax
« Reply #7 on: 17 October 2013, 22:43 »
A a pair of driving gloves for the journey home from R-tech, coz ur gona need to hold on tight :grin:
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
