Author Topic: Few problems with my golf :(  (Read 992 times)
Offline Robbiie_Cee
« on: 16 October 2013, 17:00 »
Firstly, it sometimes won't start straight away when warm, but starts fine when cold? Been told it could be engine temp sensor or coolant temp sensor?
Secondly, I've been through 3 drive shafts in a year... My car is quite low on adjustable coilovers. How do the rest of you not go through driveshafts like that? I'm not wheel spinning either. Is there any up rated parts I need to buy to be that low?
Hopefully someone can help me out. Thanks
Offline mcgee9t2
Re: Few problems with my golf :(
« Reply #1 on: 16 October 2013, 18:49 »
where abouts is DS it breaking? is it rubbing on chassis? is it rubbing on arb
in my oinion it will be rubbing on one of them and thats causing it to get weak and snap.
Offline MoshiMoshi
  • Scorpion Exhausts are delightful.
« Reply #2 on: 17 October 2013, 15:57 »
I was going to say, are you just blindly replacing drive shafts on a "oops there goes another drive shaft" basis? Surely it's a rubbing issue and that should be sorted before another one is fitted. ANY decent mechanic, or anybody who knows anything about cars could point out where it's rubbing. Have a look, it's not easy to see without getting under the car/turning the wheels/getting wet and covered in grit, but its worth a look.
Any noise? Vibrations?
I thought Volkswagens were supposed to be reliable?
Offline Mr_Orange
« Reply #3 on: 17 October 2013, 19:44 »
Hot start is symptomatic of a failing crank angle (engine speed) sensor.
Chewing up driveshafts?  Isn't that also known as lows tax?!   :grin:  Don't keep throwing money at it, get it looked over at a VW specialist.  Where you at?
Build thread clicky
Offline dom
  • Back in a Mk4
« Reply #4 on: 17 October 2013, 20:28 »
Cheap driveshafts are also renowned for giving up very easily.
Offline Adam
« Reply #5 on: 17 October 2013, 21:33 »
Chassis notch and/or R32 droplinks. Search for them using the search function.
Colt Start, like advised crank angle sensor.
Down Hill From Here.
