Author Topic: 1.8T Running Costs  (Read 4107 times)
Offline CM690
  • Golf MK4
1.8T Running Costs
« on: 16 October 2013, 13:41 »
What's a 1.8T really like to run? I do 50 miles a day, A roads and motorways in my 1.6 mk4 and it's costing me about £10 a day (33mpg) average. I'm after a new car and it's either a tdi or 1.8T.
So many cheap 1.8t low mileage examples around within my budget of £3000 but I'm worried that they will sting me on fuel. I've been looking at A3's/Leons/Ibizas and Golfs but I imagine they are all similar being the same engine!
Offline Perryd84
  • MK4 Golf 1.8T 20V GTI
Re: 1.8T Running Costs
« Reply #1 on: 16 October 2013, 14:35 »
I do 14miles a day and I scrape 20quid a week at around 25-28mpg in heavy traffic.
If I do a motor way trip like London to Brighton I can easily do a weeks worth of petrol or more in one trip  :sad:
Not the most fuel efficient car but what a way to spunk that petrol away :grin:
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
Offline CM690
  • Golf MK4
« Reply #2 on: 16 October 2013, 14:43 »
Wow, that's pretty high haha! Might rethink the TDI!
Offline navmk4gti
« Reply #3 on: 16 October 2013, 15:12 »
If you worry about fuel just go for a diesel.
Offline dom
  • Back in a Mk4
« Reply #4 on: 16 October 2013, 15:37 »
It all depends how you drive, mine is running circa 220bhp and makes a nice noise when you plant your right foot so my long term average over the last 18,000 miles is 29mpg - this is worked out using fuelly.com
http://www.fuelly.com/driver/dom069/gti
It's all down to driving style though, mine will quite happily return 36-37mpg but I didn't but a 1.8t to drive like miss daisy :grin:
Offline Nino
« Reply #5 on: 16 October 2013, 16:09 »
My 1.8t av between 370-390 per tank, full to light.
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline baka
« Reply #6 on: 16 October 2013, 16:40 »
I usually get 33-37mpg, stock map, 95 RON.
Whenever I borrow my mums 1.6 SE and do the same journey, I get the same MPG.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 16 October 2013, 19:20 »
I get 28mpg in mine due to loads of short runs
Offline james18t
« Reply #8 on: 16 October 2013, 20:18 »
I'll get about 150 miles out of £40 of v-power. Worth every penny :grin:
If you're worried about fuel, buy a diesel. The tax on a 1.8t is £250 (double to price of a diesel), might be something to think about as well.
If you do go for the petrol it's well worth looking into having it mapped as this will improve fuel economy if you can resist temptation to floor it everywhere :smiley:
Offline Scott D
« Reply #9 on: 16 October 2013, 21:01 »
1.8T's can be cheap to run if sensible with the right foot.
staying off boost and coasting when in gear i'm getting close to 40mpg driving to work and done over 300 miles since last filled up with £60 of v-power with 1/4 left.
different story when driving properly though  :grin:
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
