Author Topic: soaking wet boot!!  (Read 2649 times)
Offline Perryd84
  • MK4 Golf 1.8T 20V GTI
soaking wet boot!!
« on: 15 October 2013, 17:46 »
Noticed recently that the boot was soaking wet!! Took out the boot floor and found this gromit/plug on the passenger side that was soaked and along the side of the boot was drenched!! Does anyone know what this is?? See pics
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
Offline mcgee9t2
Re: soaking wet boot!!
« Reply #1 on: 15 October 2013, 18:20 »
be the air vent behind the bumper no doubt, below the rear light i believe... proberbly needs re-sealing.
Offline bonny
« Reply #2 on: 15 October 2013, 18:27 »
^^^ what mcgee said
The more you pay The faster you go.....
Offline Perryd84
« Reply #3 on: 15 October 2013, 18:28 »
Nice one I'll get out while theres still a bit of light and have a look
Offline dom
  • Back in a Mk4
« Reply #4 on: 15 October 2013, 19:27 »
I had a similar problem, when stripping the rear interior out it became apparent my car had had a rear end crash in the past. The back panel had not been pulled out enough so there was a gap between the boot lid and the back panel which was letting water in :rolleyes:
That's an extreme case but I tried resealing the bumper vents to no avail. Does your rear window washer work? It's common for a join in the pipe to come apart at the top of the c-pillar, when you try and wash your rear screen it just runs down into the boot.
Offline Perryd84
« Reply #5 on: 16 October 2013, 08:19 »
Funny you say that about a previous crash because after I got mine I noticed that the rear bumper doesn't line up with the rear panel on either side and sticks out by about 2mm not much but I notice it all the time.
When I bought it they said they had replaced the passenger door because or crash damage so god knows what happened to it :huh:
I'll have a look see if there's anything around there letting water in.
Offline dom
  • Back in a Mk4
« Reply #6 on: 16 October 2013, 11:07 »
With the rear bumper of mine off you could fit your fingers through the gap where the boot should have been sealing. It was also immediately obvious where the repair had been, I'd take the rear bumper off and take a look.
« Reply #7 on: 19 October 2013, 23:58 »
Remove your rear lights and check the gaskets.
