Author Topic: Rear knocking driving me crazy  (Read 4973 times)
Offline dom
  • Back in a Mk4
« on: 14 October 2013, 21:00 »
Knocks and rattles annoy the hell out of my in any car and over the last few months the MK4 has developed a very annoying noise from the rear.
It's a creaking/squeaking/knocking noise.
It usually does it going over speed bumps or any kind of bumpy road, it also does it on a flat straight road if I weave around a bit. In other words when the rear suspension is put under load or there is any chassis flex.
When it first started I thought it was inside the car due to it being quiet but now I'm pretty sure it's outside. Rear axle bushes are about 6 months old, it's not the shocks as I swapped the JOM rears for standard ones and the noise is still there.
The only thing I can think of is rear top mounts, but they don't look like they'd perish like Mk2/Mk3 ones would.
Anyone got any suggestions? It's almost at the point where I cannot stand to drive the car due to the noise :angry:
Offline Nino
Re: Rear knocking driving me crazy
« Reply #1 on: 14 October 2013, 21:13 »
Same thing happened to mine exact same thing on the rear passenger side. It happened about 3 weeks after i had my coilovers fitted. Turned out when i took it back to the garage that some bolt was lose on the suspenion
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 14 October 2013, 21:19 »
The nut on the top mounts?
Offline Nino
« Reply #3 on: 14 October 2013, 21:20 »
I asked the garage exactly what it was and he answered with "just a loose bolt"  :rolleyes:
Didn't charge me ether
Offline dom
  • Back in a Mk4
« Reply #4 on: 14 October 2013, 21:24 »
Hmmm, I tightened the nut using mole grips to hold the shaft so it's probably not as tight as it could be...reckon it's worth buzzing them up tighter with an impact gun?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 14 October 2013, 22:03 »
I reckon so mate. I thought I'd done mine up tight last time I had mine off then I went down the road and they rattled like mad lol
Offline dom
  • Back in a Mk4
« Reply #6 on: 14 October 2013, 22:06 »
It's going up on the ramps tomorrow to change a leaky driveshaft seal and fit new lowering plates for my rear bags to get the back down some more ,so i'll whip the rear shocks off again and tighten everything properly.
I'll report back with an update!
« Reply #7 on: 15 October 2013, 13:38 »
I would try new rear top mounts plus tighten the top nut a little more.
Offline davemk4
« Reply #8 on: 15 October 2013, 18:51 »
on my recent rear beam bush swap to vrs ones we found a squeek which originally thought was coming from shocker boots but it was the bush as the beam went up and down it squeeked now bearing mind the side in question the bush was in fine working order......
Also found a small squeek from spring rubber mount when moved it squeeks
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline dom
  • Back in a Mk4
« Reply #9 on: 15 October 2013, 19:24 »
Right, removed rear shocks and top mounts, retightened the top mount nut using an impact wrench and it's still no different.
I've ordered some new top mounts which I'll fit on Thursday if they're here in time.
I'm running standard gti bushes, how did you diagnose it as the bush?
As I'm on air I don't use the rubber spring mount, I have a bracket to hold the top of the bag instead:
