Author Topic: Removing turbo  (Read 2229 times)
Offline mrsaunders
Removing turbo
« on: 11 October 2013, 12:38 »
I'm removing my turbo soon because the previous owner broke a downpipe stud clean off while installing it  :sick:, found a couple of good guides but there for removing a ko3 to upgrade to a ko3s or ko4, I know it's the pretty much the same process but in both guides they remove the exhaust manifold, can I avoid doin this, is there enough access to the oil/coolant feeds?
Offline madmanmart
Re: Removing turbo
« Reply #1 on: 11 October 2013, 12:49 »
In a word... No, down pipe needs to come off.
It's a fiddley job with it off too.
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline mrsaunders
Re: Removing turbo
« Reply #2 on: 11 October 2013, 12:54 »
Nice one, yeah I'm removing the whole exhaust as I've gotta fit a new catback anyway, so I'll pull the whole downpipe out the way
Offline mrsaunders
Re: Removing turbo
« Reply #3 on: 11 October 2013, 12:56 »
Sorry i mean exhaust manifold on the block to the turbo, the guide said you don't have to but in the guide he did?  :undecided:
Offline mrsaunders
Re: Removing turbo
« Reply #4 on: 11 October 2013, 14:17 »
Anybody?
Offline Chris#101
Re: Removing turbo
« Reply #5 on: 11 October 2013, 16:56 »
Manifold need to come off so you can remove the turbo water&oil lines :)
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline mrsaunders
Re: Removing turbo
« Reply #6 on: 11 October 2013, 16:58 »
Found another good guide, can leave the mani in place and slide the turbo down to remove the lines, this is my next Saturday sorted  :smiley:
Offline Jin_C
Re: Removing turbo
« Reply #7 on: 11 October 2013, 18:54 »
I tried that once, did not work for me.
If the mani nuts aren't seized it will work out easier taking it off. The 15 mins spent taking it off will save you time trying to manoeuvre the turbo out down by the drive shaft.
1.8T AGU, K03s, 007p, pipercross panel filter, G60 + VR6 clutch and flywheel, silicone TIP, decat + boost hoses, JOM coilovers
Offline Jin_C
Re: Removing turbo
« Reply #8 on: 11 October 2013, 18:56 »
Just re-read your initial post. Have you tried just removing the broken stud while turbo is still attached? Or is there not enough of it sticking out to grab on to (Thats what she said).
Offline mrsaunders
Re: Removing turbo
« Reply #9 on: 11 October 2013, 19:46 »
Ha, no can't really tell until I take the downpipe off, if I can then result, but I'm preparing for the worst, doesn't look like too much of a bad job just fiddly, once the downpipes out the way there should be bags of room  :undecided:, just don't want another bolt pinging that's why I want to avoid removing the mani
