Author Topic: Golf auq engine problem please help  (Read 2958 times)
Offline baxxy
« on: 10 October 2013, 13:29 »
OK i have an anniversary petrol golf running stage 2 R-tech on the way home last night my car decided to through the traction light and epc light on it wouldn't rev up and the car sounded like it was running on 3 cylinders
After turning the car off and restarting it everything was back to normal run fine all the way home 30 miles.
when we scanned it there was no fault as anyone had this happen to them just dont want this happening again on the motorway cheers.....
Offline Ben@VWH
Re: Golf auq engine problem please help
« Reply #1 on: 10 October 2013, 13:32 »
Have you had the coil pack recall carried out?
Give it a scan and post the codes. More than likely coil related.
Offline baxxy
« Reply #2 on: 10 October 2013, 13:41 »
Hi yes its had brand new coil packs on recall will vagcom it late and see if it come back with anything cheers
Offline Nino
« Reply #3 on: 10 October 2013, 14:03 »
Sounds like it went into limp mode, which would suggest a pressure drop.
When was the oil pickup pipe changed? Or has it ever been done?
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline baxxy
« Reply #4 on: 10 October 2013, 14:11 »
Hi mate it's never been changed and I've owned the car 7 years do you think that could be the problem
Offline Scott D
« Reply #5 on: 10 October 2013, 16:06 »
surely it would of registered a fault code if gone into limp mode i'd of thought.
You scanned it using VCDS or a hand held device?
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline baxxy
« Reply #6 on: 10 October 2013, 16:07 »
Hi mate I used one of them supa vags but marks guna scan it later
Offline Scott D
« Reply #7 on: 10 October 2013, 16:11 »
can miss fault codes the cheaper hand held scanners but would of thought a supa vag has all known VAG codes.
is mark able code clocks now? had no reply off dave
Offline baxxy
« Reply #8 on: 10 October 2013, 17:05 »
Mark carnt do imo3..... Keep trying him he will do them
Offline Nino
« Reply #9 on: 10 October 2013, 22:25 »
Baxx, I would defo get your oil pickp changed ASAP
