Author Topic: K & N Air filter?  (Read 970 times)
Offline Jay-White-Gti
K & N Air filter?
« on: 04 October 2013, 14:23 »
Hello Golf Owners  :grin:
Just needing some quick advice im doing my first car service on Sunday, im buying my oil n fuel filter from
uni parts today was just wondering is it worth the extra money to buy a k & n air filter or does it not make much difference? Also will be changing the oil, checking brake fluid etc anything else anyone could recomend i should check?  :smiley:
Thanks
Jay
Offline james2
  • No scammers please.
Re: K & N Air filter?
« Reply #1 on: 04 October 2013, 15:02 »
you should get a pipercross panel filter
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline Luke1981
« Reply #2 on: 04 October 2013, 18:34 »
As above,  I have a pipercross panel filter. Better MPG and they have a lifetime warranty
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline mcgee9t2
« Reply #3 on: 04 October 2013, 18:49 »
id go piperx over k&n
though either should be fine.
also check the service book, tells you each thing that needs doing in each service
« Reply #4 on: 05 October 2013, 21:47 »
Pipercross foam is the best bet, K & N is oiled and will lead to maf problems.
