Author Topic: Intercooler experts required info :)  (Read 2509 times)
Offline Nino
« on: 02 October 2013, 15:33 »
Hey guys had a look at this kit and it seems to have everything I would need for my AUM, I have read there feedback and im abit concerned it seems this seller sells these kits in auctions as well as buy it now and if they don't go for a price there happy with they refund and say it out of stock, others have said they rang to ask questions about parts fitting only to find they don't. Anyway the item is below, what do you think?
http://www.ebay.co.uk/itm/350810456099?ru=http%3A%2F%2Fwww.ebay.co.uk%2Fsch%2Fi.html%3F_sacat%3D0%26_from%3DR40%26_nkw%3D350810456099%26_rdc%3D1
« Last Edit: 02 October 2013, 21:50 by Nino »
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline Scott D
Re: Intercooler experts required info :)
« Reply #1 on: 02 October 2013, 23:49 »
pipework is only 2" which will be restrictive.
best bet is a toyosports core and custom pipework, going down this route in the new year
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline Nino
« Reply #2 on: 02 October 2013, 23:58 »
Offline Dalo Harkin
« Reply #3 on: 03 October 2013, 13:03 »
I did the Toyo cooler and custom pipework route, it can be a pain getting it all lined up but much better in my opinion than the cheaper versions available
Offline Nino
« Reply #4 on: 03 October 2013, 15:24 »
I shall order mine on friday just needs to work out what piping i need to get now lol
Offline davemk4
« Reply #5 on: 03 October 2013, 15:29 »
U can get a inlet outlet on same side full kit far less joins etc for 229.00. It is 2" but there also a 2.5" version for about 350
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline Nino
« Reply #6 on: 03 October 2013, 18:09 »
Id Rather have them on ether side tbh mate :)
Offline markgti1.8t
« Last Edit: 03 October 2013, 18:23 by markgti1.8t »
AGU fk coilovers Powerflex top mounts full 3inch decat turbo back viper induction kit fmic vr6 clutch g60 flywheel catch can 007 forge dv Power flex wishbone bushes  Power flex dog mount under brace JOM  ADJUSTABLE Drop Links Walbro 255lph INLINE Fuel Pump wmi now fitted WAITING TO FIT VR6 MAF SAAB RED TOP INJECTORS STILL TO BUY K300 TURBO  CON RODS LSD
Offline Nino
« Reply #8 on: 03 October 2013, 21:16 »
Id like to win that one but its collect in person only
Offline barrym381
« Reply #9 on: 03 October 2013, 22:10 »
contact seller ask him if you can arrange a courier  :wink:
