Author Topic: Intercooler experts required info :)  (Read 2508 times)
Offline rio_gti
Re: Intercooler experts required info :)
« Reply #10 on: 04 October 2013, 10:32 »
I shall order mine on friday just needs to work out what piping i need to get now lol
ive said it a few times but check out my build thread I got the list of whats needed there  :wink:
Offline sharki786
  • GOT BOOST??
« Reply #11 on: 04 October 2013, 11:53 »
Id like to win that one but its collect in person only
His around the corner from me. I could always pop down and get one for you and have it sent to you?
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Nino
« Reply #12 on: 05 October 2013, 01:40 »
Doh wish I saw all this before I bought the otherone, never mind. :)
I am going to order my pipes soon and follow Pawnys suggestion, but Im really confused on what I am supposed to do with the two pipe that come off the standard charge pipe??  :huh:
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline sharki786
  • GOT BOOST??
« Reply #13 on: 05 October 2013, 10:57 »
Minor :wink:
*****MK4 GTI T*****
Offline davemk4
« Reply #14 on: 05 October 2013, 12:55 »
Just curious when you can get a full kit inlet/outlet same side for 125 delivered by auction why buy a diy kit? Are the inlet/outlet same side not as good or summit? I thought they be better as slot less issues with leaks as far less joins.
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline james18t
« Reply #15 on: 05 October 2013, 17:12 »
I went for the THS kit. It fits a lot better than the ebay kits and if you want to use your original grilles you just have to trim them a bit. Used ones come up from time to time. I've had mine fitted about a year now and never had any problems with leaks etc. after being stage 2 mapped.
